Toyota 4Runner 1984-2002: Why Does My Alarm Keep Going Off?
Repair a faulty vehicle alarm in your Toyota 4Runner using these straightforward tips, and save yourself a lot of aggravation in the process.
This article applies to the Toyota 4Runner (1984-2002).
A faulty factory or aftermarket alarm can be one of the most bothersome problems you face as a (1984-2002) Toyota Tacoma owner. But that doesn't mean you have to put up with it; at least not for long. Thanks to some pretty straightforward do-it-yourself tips and troubleshooting advice, you can fix a malfunctioning factory or aftermarket alarm on your own. This guide will walk you through the things you'll need to look for as well as explain what you should do once those problem areas have been diagnosed.
Materials Needed
- Replacement battery
- Voltmeter
Step 1 – Change the alarm mode
It might be in "valet" mode.
If you've recently disconnected and then reconnected your battery, it's highly likely you triggered your alarm to automatically enter into "valet" mode (versus "keyless entry") when your doors open.
- Check beneath the dashboard for a toggle switch.
- Use the switch to exit out of "valet" mode and back into "keyless entry" mode.
- This is a simple fix that should not require the help of a mechanic. If it does, expect to pay very little for the repair (if anything at all, depending on your relationship with the mechanic).
- You will see a blinking light whenever your alarm is activated.
Pro Tip
If you have a factory alarm, you may be able to disable it by placing your key in the door, and then locking and unlocking it.
Step 2 – Check the battery
It might be on its last leg.
If the voltage is too low in your battery, you may notice that your alarm is triggered every time you attempt to start your car.
- The problem occurs because your car can not crank up properly; thereby, causing your alarm to sound.
- Low battery voltage and cold weather can both cause this problem to occur; however, a bad battery is the most common culprit.
- Read the level of voltage in your battery using a quality voltmeter.
- Change your battery if the voltage is too low; otherwise, your alarm will continue to sound.
- This repair should cost you around $100-$150, depending on the cost to replace your old battery.
Step 3 – Check the alarm
It might have a bad sensor or other malfunctioning component.
The wiring in your alarm could be bad, causing it to go off randomly. It will need to be carefully checked for damage and looseness.
- Inspect the wiring for a loose connection or poor grounding.
- As well, check for a bad shock sensor.
- It's also recommended that you check that the shock sensor is not adjusted too high, which would make it highly temperamental.
Related Discussions
- Factory Alarm Problems - Yotatech.com
- Random Alarm Engagement - Yotatech.com
- Bad Grounding - Yotatech.com
