GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
No Transmit Response - SWR Tested on New CB
Old 12-01-2012, 01:49 PM
nojack's Avatar
I had a problem with the antenna mount. It was painted so it did not ground. I removed the paint at the bolt/washer contact and now I have SWR readings that are satisfactory. 1 at Channel 1, 2 at Channel 40. (I know, I know...shorten the antenna.) But the readings are safe for now. I cannot get a response on my transmits. Mike/Transmit gain is turned up. Bearcat 880 Uniden. Finally the question. Is it still possible to have a ground problem if my SWR meter functions perfectly when installed and tested?
Nojack
Old 12-01-2012, 11:50 PM
VegasNick's Avatar
Probably not. Chances are that you just aren't reaching out there. I'd get a buddy to help you out from his rig, or you can always try the local truck stop on ch 19. SWR of 2 isn't the best, but isn't the worst either. Not a radio killer.
Old 12-03-2012, 06:22 AM
nojack's Avatar
Thanks. Will give it a try.
moparbay
03-10-2023 03:50 PM
eggens
10-27-2015 03:14 PM
_Nicco_
09-21-2015 03:06 PM
larrys93pickup
09-17-2015 07:05 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: No Transmit Response - SWR Tested on New CB
