Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Radio Dash and Double DIN Radio 1988 4Runner
Old 03-22-2012, 06:51 AM
jorgonzalez's Avatar
Hi, i got my 4Runner for over a year now, doing some restoration on the interior, i cant seem to find the radio dash here in my country, so i looked up for a replacement one over ebay, i just ordered, lets hope it fits, also i would like to know if any of you have installed an aftermarket double din radio, if so tell me wich model fits properly. Thanks
Old 03-22-2012, 06:59 AM
Bassmastry101's Avatar
I've never tried a double din in these trucks but I'm sure you could make it work with a little creativity.
Welcome to yotatech!
Old 03-22-2012, 07:02 AM
Thanks man!
Ok, so its made for single din then?
Old 03-22-2012, 07:10 AM
No problem. Yes, there was a pocket or just a blank plate under the radio. However, If you wanted to I don't see why you couldn't stuff a double din in there.
Old 03-22-2012, 06:13 PM
drpdmazda's Avatar
that truck should accomodate a double din radio with little to no modifications to the outside housing. (the part that has the ash tray in it and surrounds the radio) it will mount using the factory metal radio brackets and should wire up like any other head unit with a toyota harness, minus any brake bypasses you may want to do to get video while driving.
Old 04-03-2012, 11:39 PM
clok's Avatar
I just put a double din dvd player in my 89 4runner , the bottom pocket under the radio was cut out so it would fit in there and used the factory radio brackets, it fit just right.
Old 04-09-2012, 12:30 AM
autoadas's Avatar
it should be univeral double din ,right?
Old 04-09-2012, 09:12 AM
clok's Avatar
Yes I belive so . The side of the radio should have holes were the factory brackets screw into there should be three levels to screw into I think I used the bottom level so it seats centered in the dash but you may have to choose one of the other levels to center yours depending on which radio you choose to get but it will fit , I will post a picture when I get home.
Old 01-13-2013, 01:14 PM
tmcaron's Avatar
Any pictures of the double din? I have been thinking about it but I'm not sure if I want to go touch screen or what. This is what I have as of now.
Old 03-21-2013, 03:16 PM
1quickbabydill's Avatar
a little trimming and home made brackets. works great.
Old 08-25-2013, 11:59 PM
jenniedsy's Avatar
i have been also using 2 din DVD player from happyshoppinglife for one year. it works great and there are no other issues
Old 10-22-2013, 07:01 PM
White88runner's Avatar
It's been years but when I did mine I had to trim the plastic to fit any dash kits
Old 02-01-2018, 02:10 AM
HAMBONE1039's Avatar
I'm not sure as to whether or not a double din would fit inside the opening for an 88, but I know that my 7" fit with a little light sanding and used my dremel around the inside bezel. I also don't have to use any kind of dash kit because my double din bolts right up to the factory radio mounting brackets which makes it kind of nice because that would be a giant pain in the back end to pull that out of there if you weren't supposed to be lol.
ashersullivan88yota
01-18-2022 05:37 PM
mskalmus
05-28-2017 07:51 AM
andrewtexas123
07-14-2015 04:29 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Radio Dash and Double DIN Radio 1988 4Runner
