Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
2nd Gen Factory Speaker Replacement Help
Old 07-21-2006, 07:04 AM
ricky's Avatar
Originally Posted by ldivinag
3. get a nice subwoofer
4. 4 channel amp to power all speakers. bridge 1 pair to power the sub. other 2 to power the front doors speakers. dont bother with rear speakers, unless you carry passengers back there all the time. you really dont need rear speakers unless you havea 5.1 DVD setup. stereo is still king. adding rear speakers can just ruin the setup.
When choosing a 4 channel amp, to be run in a configuration where 2 channels are stereo, and 2 channels are bridged, you have to remember that if both loads off of the amp are 4 ohm loads, the stereo channel is going to get half of the power that the amp can actually kick out. This is the case with MOST amps, but there are some out there that are not this way (more expensive).
So, for example: 300 watt amp
150 watts bridged @ 4 ohms (chan 1&2)
38 watts per channel stereo @ 4ohms (chan 3&4)
-vs-
75 watts per channel stereo @ 2ohms (chan 3&4)
This can become more complicated depending on how many speakers are attached to each channel. Because if you take 2 4ohm subs and run them in parallel, you will end up with a 2 ohm load, whereas if you run them in series, you have an 8ohm load.
The load combination between the two channels is of extreme importance if you are going to buy an inexpensive amp that runs in this manner. If you want to get the most wattage out of every channel, be sure you're using the correct combination.
Old 11-21-2023, 05:19 PM
its_ru's Avatar
What are the side speakers and rear speaker sizes?
Originally Posted by AJwhoisthat
Im actually having problems getting my back panel speakers to work after i installed my new HU only the speakers above the rear window work... so im stumped because here is the catch. The back panel speaker and the speaker over the window are wired together. I took these pictures today and still havnt figured out my problem so if anyone has an answer to that then sendd some help my way.
im looking at these pictures and realize there’s 6 speakers total.
2 Front , 4in Speakers”
2 Side , 5.25in Speakers
And 2 rear speakers??? What size are those?
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd Gen Factory Speaker Replacement Help
