My $65 4Runner Bikini Top
Old 07-09-2007, 12:58 PM
4runnerx3's Avatar
I've had several PM's from people wanting to know about my top. I got the top from TPI, a landcruiser supplier, it's a top for a fj40. The only mod I did to the top was to have the rear straps shortened 10". I went to Lowe's and got a stick of conduit and a 1" by 1/8" by 8' piece of aluminum flat bar. I bent the flat bar to the curve of the cab/top. Some of the extra was cut and bent to make the 4 bolt brackets.
I bent the conduit, drilled holes at each end and wiped it down with lacquer thinner and painted it black. I got a 1" wide velcro strip to help support it in the middle.
The footman ,loops which came with the top, were mounted at the back corners.
Old 07-09-2007, 01:14 PM
4runnerx3's Avatar
TPI 615-826-8853 The top was $45.
Old 07-09-2007, 01:32 PM
Knuckles's Avatar
this is why i want a first gen! do you have more pictures with the top?
Old 07-09-2007, 03:58 PM
4runnerx3's Avatar
It's raining today, I'll take some pics tomorrow.
Old 07-09-2007, 04:28 PM
FOCUSHERE's Avatar
hey whats TPI? what is that website and what kin of plating didi it come with to mount it to the roof?
Old 07-09-2007, 04:46 PM
INFINITY's Avatar
nice, very nice, thanks for the info
Old 07-09-2007, 05:28 PM
InternetRoadkill's Avatar
http://www.tpi4x4.com/Tops.html
Old 07-09-2007, 05:34 PM
4runnerx3's Avatar
Thanks Internetroadkill, I couldn't find the little catalog they sent me. The top I used is the $45 one, the "family" top is too long.
Focushere, the top didn't come with anything to mount to the cab, just footman loops at the rear. I made the metal "band" and angle braces to pinch the top against the cab. The top has a wand sewn on that end to slide into a track. I just pushed that thicker part below the metal band to pinch it against the weatherstriping.
Old 07-09-2007, 05:42 PM
colsoncj's Avatar
Could you take some more detailed photos of how you attached it to the cab, and the parts you used when you do take some pics? Nice work!
Old 07-09-2007, 06:16 PM
swerks's Avatar
is it difficult to bend the flat bar to contour the roof line?? how much conduit??
Old 07-09-2007, 06:23 PM
4runnerx3's Avatar
I bent the flat bar against an extra top I have that I have cut out the side windows. I layed the metal on top of the fiberglass top and bent it against tapping with a hammer. I don't remember how long the conduit was, I filled it with sand and taped the ends (no pipe bender) and bent it and cut the extra off.
Old 07-09-2007, 06:25 PM
FOCUSHERE's Avatar
Man this is going to be a hot thread!
cant wait for those pics of how you attatched it! thanks for this sweet mod!(cheap mod lol)
Old 07-09-2007, 06:30 PM
4runnerx3's Avatar
I couldn't believe this on ebay a couple of weeks ago.
there's one born everyday.
More pics coming tomorrow.
Old 07-09-2007, 06:31 PM
FOCUSHERE's Avatar
i cant belive that ebay wow! hey thanks for not keeping this a secret and sharing the mod!
Old 07-09-2007, 06:37 PM
dcg9381's Avatar
Looks great! Thanks for sharing!
Old 07-10-2007, 03:09 PM
4runnerx3's Avatar
OK, more pics. First, this is the dumbass way I came up with last year to hold the top to the cab. I cut a 2x6 to work.
Then I was looking at some pics showing how a CanBack top mounted and got the idea to use the metal. It's alot easier to mount.
This is the conduit I bent and painted.
Old 07-10-2007, 06:45 PM
FOCUSHERE's Avatar
does the front of the bikini top have like a round peice of metal or something stiched to it?............so you just layed down your top across yourangle peices then layed down that peice of meatl you bent then tighted the screws on top of the little angle peices?
Old 07-10-2007, 06:50 PM
4runnerx3's Avatar
Yes, it has a round bendable wand sewn in the front edge. You can see it in the first close up shot of the aluminum flat bar.
Old 07-10-2007, 06:53 PM
FOCUSHERE's Avatar
well just an idea.......
i went to a local upolster shop and the have this sweet peice of aluminum like you have bent there but laying flat aggainst the truck you would have to drill you some holes but it has like a small "pipe" welded on that that peice might slide into then it has a opening on top across the whole bar so it can fold back does that make since?
Old 07-10-2007, 07:01 PM
4runnerx3's Avatar
Click on the TPI link above, scroll down to the windshield rail, something like that?
Quick Reply: My $65 4Runner Bikini Top
