California NorCal California NorCal Chapter
1990 4runner miss/hesitation
Old 12-19-2012, 07:23 PM
surfer150's Avatar
Hi all.
This is my 1st question on this forum. I just bought my son a 1990 4runner with the v6 engine. It cannot pass smog and has a miss. We have done a total tune up. Things got better but then we did a compression test and found the #4 cylinder read 15psi all others were 125-135psi. We added the tablespoon of oil and it did not come up. So what i've read, that eliminates the piston and rings but says we have a prob with with the valves. My real question is, do we need to do a head job or could it be just need a valve adjust. We bought this truck from a guy who just did major work to the engine. Brand new "blue" gasket material on all. Any answers would be much appreciated.
Thanks!
Old 12-20-2012, 06:14 PM
surfer150's Avatar
YotaTech Forums
Photos
Members
Tech Tools
MarketPlace
Wiki
surfer150
Go Back YotaTech Forums > Regional Forums > 4ROC > California NorCal
Reload this Page 1990 4runner miss/hesitation
Welcome, surfer150.
You last visited: 12-19-2012 at 10:10 PM
Private Messages: Unread 0, Total 0.
Home Photos User CP Albums Chat Blogs FAQ Members New Posts Search Helpful Links vBLive Vendors TSBs Log Out
Please note if you have less than fifteen posts, you will not be able to start a new thread in any of the Classified forums.
Click Here
LinkBack Thread Tools Search this Thread Rate Thread
Old 12-19-2012, 08:23 PM #1 (permalink)
surfer150
Personal Sales Rating: (0)
Hi all.
Thanks!
surfer150 is offline Report Post
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Quick Reply
Message:
Remove Text Formatting
Bold
Italic
Underline
Insert Link
Insert Image
Wrap [QUOTE] tags around selected text
Decrease Size
Increase Size
Options
Quote message in reply?
« New independent toyota repair shop in Placerville! | - »
Posting Rules
You may post new threads
You may post replies
You may post attachments
You may edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - YotaTech - Archive - Top
Advertising - Privacy Policy - Terms of Use - Jobs
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
Old 12-21-2012, 11:07 AM
toytech76's Avatar
You will more than likely need a complete valve job. You cannot grind the exhaust valves as it will cause them to burn again quicker. They muct be replaced. You can grind the intakes. Very very common problem with those motors. If the compression wasnt so low, you might be able to adjust them, but with it being only 15psi...its already done. A good head job using toyota parts and gaskets will make it right
Flying91
45
04-11-2024 04:39 PM
MMA_Alex
25
04-18-2017 05:07 AM
BeMiceElf
10-10-2015 09:40 PM
madxman21
07-09-2015 10:26 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 4runner miss/hesitation
