Winching Questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-19-2008, 01:42 PM   #1 (permalink)
swapped89's Avatar
Winching Questions
I just installed my new WARN 8000 and have a question. Should i leave the motor running while winching, the book said not to. but i think it would help keep from draining the battery.
__________________
SAS 89,trussed, bobbed, Trail Gear front & rear 5''. 3.0 V6 cold air k&N, 40 ser. flowmaster, 5speed, HP ARB font diff, Marlin Crawler inner's and marfields. 5.29 yukons, Detroit rear, 35''x13.5 toyo's. Steadily growing body damage. Two way alarm, TG rock defense bumper, Warn 8000, TG crossmember,geard rive t-case w/marlin XD 4.7s. TG Sliders, some day dual cases and a cage
swapped89 is offline
Old 12-19-2008, 01:46 PM   #2 (permalink)
Bru
Bru's Avatar
what type of battery are you running? well you will drain it with any good pull you do. leave the motor running. my 2cents.
__________________
Bru
IYAAYAS!!!
83 P/U, 5" lift, 35" tires, locked and welded, and it will never be done
www.BigHorn4x4Club.com
www.U4WDA.org
Bru is offline
Old 12-19-2008, 01:49 PM   #3 (permalink)
swapped89's Avatar
my battery is a lesschwab battery only 650 cold cranking amps. just the minimum rating for my winch
__________________
Old 12-19-2008, 05:35 PM   #4 (permalink)
GSGALLANT's Avatar
I always leave my truck running when winching and I am running my winch off an auxiliary optima blue top battery. With the truck running, you are able to help the winch along by having the truck in drive while you're winching (depending on the situation you're in). The battery voltage will also be slightly higher (15% or so) with the truck running, which will cut down the amps that the winch draws.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 12-19-2008, 05:42 PM   #5 (permalink)
tc
tc's Avatar
x2 GSGALLANT
I would call Warn and ask "WTH are you thinking saying engine off when winching"?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-20-2008, 06:32 AM   #6 (permalink)
I have a Warn 8274-50 on my Jeep and always leave it running when winching.
Rockram is offline
Old 12-24-2008, 12:49 AM   #7 (permalink)
Johannes's Avatar
Send a message via AIM to Johannes Send a message via Yahoo to Johannes
They don't want you to do something dumb while winching, like use the winch as a tow strap too...it's a liability issue, they're just protecting their hides.
Question though, Warn seems to be the industry leader and standard in winches, but it looks like there's a lot of winches to choose from these days. Anyone used another brand (besides Ramsey, I like them too) and have anything to say?
__________________
Own:
1985 Toyota 4Runner
Owned:
1995 Toyota Pickup 4x4
Johannes is offline
Old 12-24-2008, 03:08 AM   #8 (permalink)
EvaMonky's Avatar
Send a message via Yahoo to EvaMonky
Quote:
x2
Plus if the engine is running, people might put an Auto in Park and not Neutral.... Not good while it's getting pulled along with a Winch.
But I guess someone could do that while it's off too lol.
Maybe it's because on older Vechicles, running the motor while whinching might cause the Electrical System to overheat? Spark? I mean you choose your potential disaster.
In the end it's all about lawyers.
__________________
Consequences dictate
our course of action
and it doesn't matter what's right.
It's only wrong if you get caught.
If consequences dictate
my course of action
I should play GOD
and shoot you myself.
I'm very tired of waiting.
EvaMonky is offline
Old 12-24-2008, 10:07 AM   #9 (permalink)
tc
tc's Avatar
I think it would be MORE common if the engine was off. It's gets to be quite an ingrained habit to make sure it's in park before turning off the engine (because otherwise, you can't get the key out)
Like I said, I can see NO reason to turn it off and TONS of reasons to keep it running...
__________________
tc is offline
Old 12-24-2008, 10:15 AM   #10 (permalink)
fireman1559's Avatar
i love my dayton its a good winch i always leave my truck running while i pull if you turn your truck off to winch someone will be pulling you out of where ever you are and trust me tow truck drivers hate when you get there trucks dirty
__________________
1990 model SR5 3.0 automatic 3in bodylift 4in rough country liftkit.
mods soon to come:new trans and transfer case, 35 or 36s, 5.29s and a lockrite, manual locking hubs
fireman1559 is offline
Old 12-24-2008, 10:20 AM   #11 (permalink)
TOYOTA 1's Avatar
Quote:
^x2..
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 12-24-2008, 10:36 AM   #12 (permalink)
Johannes's Avatar
So to go along with this, I have a Warn 800 on my Runner and it's kind of beat up, and been exposed to the elements for a long time. I picked up the truck a couple of months ago and it's been used before (the line is crap, fraying in places).
Anyone ever changed a winch line? Cant be that hard right?
Anyone have a Warn 800 Remote lying around that they'd want to get rid of?
__________________
Own:
1985 Toyota 4Runner
Owned:
Johannes is offline
Old 12-24-2008, 10:39 AM   #13 (permalink)
tc
tc's Avatar
It's easy - take the opportunity to go with synthetic - you'll wonder how anyone still uses wire rope!
__________________
tc is offline
Old 12-24-2008, 11:09 AM   #14 (permalink)
Johannes's Avatar
Wait, I've seen those on Ebay, but like climbing rope, doesn't it degrade when exposed to sunlight?
__________________
Own:
1985 Toyota 4Runner
Owned:
Johannes is offline
Old 12-24-2008, 11:44 AM   #15 (permalink)
crackerjack's Avatar
I let my engine run, besides better voltage I think it helps to pull cooler air over winch motor.
__________________
33x12.5x15 pro-comp front/Swampers back , L.C Eng. cam,pistons,header, Crane multi spark ignition, Zoom Carbon clutch,etc. 8.5 Ramsey winch,4:88 gears open front, spool back. Vs2 backup camera, Lowrance GPS, Sirius Sat Radio, Tacoma bucket seats, tube doors, AllPro sliders and rear bumper Budbuilt crossmember....Thanks Yota Tech links to most this stuff
crackerjack is offline
Old 12-24-2008, 05:57 PM   #16 (permalink)
tc
tc's Avatar
No - they are UV stabilized. Check out winchline.com or amsteel
__________________
tc is offline
Old 12-24-2008, 07:44 PM   #17 (permalink)
Johannes's Avatar
Sweet, that's pretty awesome. Thanks for the info. I guess my only concern is what they already warned, sharp edges on bumpers and trees.
__________________
Own:
1985 Toyota 4Runner
Owned:
Johannes is offline
Old 12-25-2008, 04:53 PM   #18 (permalink)
TrikeKid's Avatar
Tree savers are cheap, there is no reason to be putting bare winch line around a tree in a recovery situation. They can also be used to wrap around a bumper if you're like me and have friends that don't have any tow points on their rigs.
__________________
'85 Xtra Cab
Knobbly tires and such things.
TrikeKid is offline
Old 12-25-2008, 05:14 PM   #19 (permalink)
sa51's Avatar
Quote:
agreed, i cant stand when people wrap their cables around bumpers or trees. damages the tree and kinks the line.
__________________
Olive Drab 1995 4WD regular cab pickup,22re, 33x10.5 BFGs,doetsch tech prerunner shocks, all pro shackles,sway bar delete.
Quote:
Originally Posted by the_ocho
so long story short. dont look at other yotas. it causes head gasket failure
Quote:
originally posted by a4runnerfreak
Hey SA.....just time for a new, younger, more improved model, thats all. 1 that is trainable. Just make sure she's of age......:D
TREAD LIGHTLY
sa51 is offline
Old 12-25-2008, 09:31 PM   #20 (permalink)
tc
tc's Avatar
In many cases, it will kill the tree. If you cut through the bark on a significant portion of the circumfrence, the tree will die. I think it's called ringing the tree.
__________________
tc is offline
Old 12-26-2008, 12:12 AM   #21 (permalink)
glenyoshida's Avatar
Quote:
I think you may have misread it. If you do find that it does say to turn off your vehicle while winching I'm not to proud to admit I'm wrong. When you winch under a heavy load you can drain a battery dead in less than 15 minutes. A winch under a heavy load will pull the battery voltage low and therefore make the alternator work hard. There is a low risk of burning your alternator out but it's small and uncommon. You also make the alternator work hard if it has to recharge a dead battery so you are not saving the alternator by winching with the engine off. Regular car batteries like to stay topped off. So if you do decide to run your winch with the engine off you are also shortening the life of your battery more than if the vehicle is running. Even the optima yellow tops prematurely lose life when you drain the battery low.
It's not hard steel or otherwise. Synthetic is much easier to handle. Splicing is not complicated although I'd recommend practicing it a few times before relying on it. Neatness counts on the splice. Remember to condition your steel line by making sure there is a small load on the line when spooling it for the first time. Remember to get a rock guard for your synthetic if you go that route.
Sure can. It's important to make sure it's been treated for UV resistance. Technora for example loses 50% of it's strength in 1.5 months if it's untreated. Even treated they lose 50% strength when exposed to the sun for 3 months. So whether you go with technora (Tech 12) or Amsteel Blue you should cover your lines. This includes the area of exposed rope around your thimble/hook.
Amsteel Blue is the most popular but it can lose half it's line strength if the drum gets warm at 160 F° and the drums commonly do get that warm. Technora loses half it's strength at 450 F°. Something else to consider is that although you tend to get little cuts on your hand with steel it doesn't mind rocks like synthetics do. I prefer synthetics because it's easier to handle but it does take more care and paying attention than steel.
__________________
- Glen
2001 4Runner SR5 Auto - Armorology Front Bumper, Warn M8000 w/hidden solenoid - Wireless remote, 1/2" Technora winch line & Safety Thimble - Toytec coilovers - OME 891s w/Bilsteins - Yokohama Geolander MT+ 305/70R16 - Stubbs HD-SKO Sliders - Engel 15 Freezer - Toytec Rear LCA skids - Budbuilt front and belly skids - Low profile cargo - Laptop mount - Thule aluminum roof basket - Viper 5 channel remote start two way paging model # 5900 - Cobra 8WSXTII CB Radio - Stainless rear bumper
glenyoshida is offline
Old 12-26-2008, 12:22 AM   #22 (permalink)
stagger_lee's Avatar
__________________
07 FJ, 6 speed
84 4Runner
Quote:
Originally Posted by scuba View Post
I've spent 3 months trying to figure out exactly who you are. And you just summed it up in 2 sentences !! :dj:
stagger_lee is offline
Old 12-26-2008, 12:28 AM   #23 (permalink)
sa51's Avatar
that is correct.
__________________
TREAD LIGHTLY
sa51 is offline
Old 12-26-2008, 01:10 AM   #24 (permalink)
85TurboRunner's Avatar
At the moment I have no choice. There is a short somewhere in my system and whenever i use the winch my engine dies. But having the engine running while winching seems like a better idea to me.
__________________
1985 4runner 22re 5spd.
85TurboRunner is offline
Old 12-26-2008, 08:31 AM   #25 (permalink)
tc
tc's Avatar
Sounds like you need to figure it out before ever using the winch again... kinda hard to get off the trail with your entire electrical system burned down!
__________________
tc is offline
Tags
ashtray, at160f
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
winching over Ric Off Topic Talk 12 09-14-2007 11:39 AM
Winching with an Automatic Transmission Mojo_Risin Offroad Tech 20 04-11-2007 01:20 AM
perfect winching setup northfacer581 Offroad Tech 42 03-10-2006 09:56 PM
Winching (self-recovery) RTdawgs Offroad Tech 4 07-08-2004 06:50 AM
MN Wheelin and Winching (couple pics) transalper 95.5-2004 Tacomas & 96-2002 4Runners 3 05-05-2003 07:49 AM
Content Relevant URLs by vBSEO 3.1.0
2009 InternetBrands, Inc.
