6 lug wheels
Old 03-12-2006, 05:00 PM
Rocklobster's Avatar
6 lug wheels
are the 6 lug pattern toyota trucks use the same as chevrolet 6 lug? Just wanted to find out before i buy a set of wheels from a chevy truck.
Old 03-12-2006, 05:15 PM
89macrunner's Avatar
i think the only chevy that the bolt pattern is the same from is the k5 blazers
the bolt patter for our yotas is 6x5.5
Old 03-12-2006, 05:24 PM
really? can anybody say for sure b/c these wheels are a steal and i need to let the guy know.
Old 03-12-2006, 05:30 PM
marko3xl3's Avatar
Find a pic of the wheels and i'll tell you.
Old 03-12-2006, 05:33 PM
dragr1's Avatar
You will need to also check the size of the center bore-if I remember correctly the spare wheel from my '04 Z-71 would not fit on my Toyota. Also the backspacing and offset should be checked.
The following users liked this post:
emsvitil (12-23-2021)
Old 03-12-2006, 05:37 PM
so it might be wise to just pass up on these wheels?
Old 03-12-2006, 05:38 PM
BajaRunner's Avatar
No, most chevy lug patterns are the same as toyota.. they are 6 on 5.5
Old 03-12-2006, 05:41 PM
marko3xl3's Avatar
Are Chevy rims lug-centric like Toyota's? I think someone once said they are hub-centric which would give you some vibration problems, depending on how big the difference is.
Old 03-12-2006, 05:42 PM
dragr1's Avatar
They are hub centric on the Chevy.
Old 03-12-2006, 05:51 PM
FYI stock backspacing on first gen rims is about 4.25in i belive
Old 03-12-2006, 06:42 PM
is this going to cause a major headache then when i got to put the wheels on?
Old 03-12-2006, 06:48 PM
JackKnife's Avatar
The main problem with most Chevy rims is that the center hole is too small to fit on a Toyota hub.
Old 03-12-2006, 08:21 PM
Silver_Truck's Avatar
why not try em first?
Old 03-12-2006, 08:41 PM
well i would test fit them but the guy isnt local
Old 03-13-2006, 10:38 AM
grimpy's Avatar
I think Chevy has a big bore and a small bore... The big bore Chevy setups would fit but not the small bore...
Old 03-14-2006, 06:25 PM
slosurfer's Avatar
Make sure to check the backspacing. I was looking at some rims and they said the backspacing was like 5 in. or something like that. I don't remember what year chevy they were from.
Old 12-23-2021, 01:32 PM
Macm2525's Avatar
Does anyone know what brand this is
39 Thieves
01-06-2017 01:08 PM
NCRidgeRunner
08-13-2015 04:11 AM
Up&Down
08-05-2015 06:20 AM
Luvmeye22re
08-04-2015 03:53 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: 6 lug wheels
