99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
tundra TPS sensor
Old 01-26-2004, 08:48 PM
alexg1323's Avatar
tundra TPS sensor
can somone tell me the specified resistance values for the throttle position sensor on the 2000 tundra. I dont have the book and this is all i need to know. thanks.
Old 01-27-2004, 01:52 PM
Mohamed's Avatar
Re: tundra TPS sensor
I'll look it up tonight and get back to ya.
Old 01-27-2004, 07:05 PM
alexg1323's Avatar
thanks
Old 01-27-2004, 08:19 PM
Mohamed's Avatar
Originally posted by alexg1323
thanks
Oh thanks for replying, I almost forgot.
Anyway, the manual accord to SF-31, states that for the 2UZ-FE engine (V8), the resistance is 1.25-2.35 kOhms at 20C (or 68 F) in between terminal VC & E2. If you need me to fax over where the measurement needs to be taken off the terminal, pm me with a valid fax number.
Oh almost forgot, if you need the 5VZ-FE (V6), it indicates to add vaccum to throttle opener and measure resistance on terminal for
1) Fully closed - between VTA & E2 - 0.2-5.7 Kohms
2) Fully open - between VTA & E2 - 2.0-10.2 Kohms
3) unknown - between VC & E2 - 2.5-5.9 kohms
Old 01-27-2004, 09:28 PM
alexg1323's Avatar
Yea i need the resistance range for the throttle position sensor on the V8 i know it must be off i keep getting a CEL for intermediate and high voltage from the TPS. If you can give me the opened, closed, and installed ohm ranges for the V8 id be much indebt thanks a bunch
Old 01-28-2004, 06:32 AM
Mohamed's Avatar
From what I remember in the manual, no ranges where given as far as position, just the range that you see there of 1.25 - 2.35 kOhms resistance.
I look again tonight, but I think that's all that was in the manual.
Old 01-29-2004, 07:08 AM
Mohamed's Avatar
Ya I checked it out, that's all it says in the manual, that range.
Old 03-06-2020, 10:35 AM
Davidk502's Avatar
Need the ohm rating for the 4.7 V8 tps 2000
What is the ohm setting and idle voltage for the 4.7 l V8
2000 Toyota Tundra? Please and thank you. Can't seem to find information on this anywhere
Gone Fission
01-12-2023 10:34 AM
Blamalam
03-12-2022 07:34 AM
Blamalam
08-16-2015 12:29 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: tundra TPS sensor
