99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old 02-09-2016, 04:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota Tundra 4WD - Four Wheel Drive Guides
Print Wikipost
Tundra 4wd conversion
Old 01-09-2021, 06:07 PM
  #41
FirstGen_Issac's Avatar
I Found a few wrecked Tundra, I have a 2004 2WD DC and wanted to know what years can I buy for the 4wd parts. Mainly wondering if the 4wd ecu and harness are the same. thank you
Old 01-09-2021, 06:08 PM
  #42
Did you end up doing this?
Old 01-10-2021, 07:06 AM
  #43
witman69's Avatar
No Sir. I never got confirmation from anyone who used an 05. I plan to buy a 2010 4wd at some point. Br Jerry
Old 03-10-2022, 04:16 AM
  #44
hunterm12's Avatar
2002 Toyota Tundra 2wd-4wd
I went to the junk yard and found a 4wd sequoia and pulled all the parts but the transmission is a knob shifter and not a button shifter would this still work?
Old 05-28-2022, 07:06 AM
  #45
theferg's Avatar
I know this is a few months old now, but do you mean transfer case is knob shift? Cause, yes, the manual lever shift Sequoia transfer case will work fine in the tundra. Its been done in 4x4 Tundras just for the fact of having the manual lever instead of the button push. Also has been used in other conversions as well.
I'm not certain, but you *might* have to cut open the trans tunnel a bit (for the shift lever) and then you would need the Sequoia shift cover that will fit right into the Tundra center console (or if no center console, just use a shift boot from like a tacoma or t-100)
milowilli
57
03-20-2021 05:14 PM
BlazeN8
07-22-2015 05:46 PM
3uzfte
All Other Toyota Swaps
39
08-30-2013 07:19 PM
apimpdad
06-23-2011 07:47 AM
UKMyers
10
11-26-2008 09:19 PM
Quick Reply: Tundra 4wd conversion
