Elite Series Fog Lamps | Diode Dynamics
Sponsor
Factory fog lights are built to meet minimum output requirements. Every aftermarket design available provides similar lackluster performance, but with an LED. The focus has been on LED appearance, not increased output. There has never been an aftermarket fog light designed from the ground up for performance - until now.
Diode Dynamics is excited to introduce our Elite Series Fog Lamps!
Toyota Fitment List (Type-B Bracket):
- Toyota Avalon 2007-2011
- Toyota Camry 2007-2015
- Toyota Corolla 2009-2016
- Toyota Highlander 2008-2019
- Toyota Matrix 2009-2013
- Toyota Prius 2010-2011
- Toyota Prius 2015-2016
- Toyota Prius C 2012-2016
- Toyota Prius V 2012-2016
- Toyota RAV4 2006-2012
- Toyota RAV4 2016-2021
- Toyota Solara 2007-2008
- Toyota Tacoma 2012-2021
- Toyota Tundra 2014-2021
- Toyota 4Runner 2014-2022
- Toyota Venza 2009-2014
- Toyota Yaris 2006-2014
The first OE-style fog lights that were designed for true performance. With a custom-engineered patent-pending optic, multi-die automotive emitters, and high-power full-copper circuit boards, the Elite Series fog light delivers up to 5 times more output than halogen lamps. With a plug-and-play installation, this is one of the easiest and most effective upgrades you can make to improve your visibility in inclement weather.
Output that Outperforms. The Elite Series Fog Lamp is built around a highly-engineered single-piece PMMA lens. This optic was carefully designed using advanced optical simulation software to produce a light pattern that is wider than any other aftermarket fog lamp on the market, with an 80-degree spread of highly intense light. Even with this extremely wide band of light, the pattern is extremely smooth throughout, with an extremely sharp cutoff to avoid glare to other drivers, including a BMW-style “color flicker” at the very edge of the pattern. Diode Dynamics engineers accomplished all this while still meeting SAE F3 fog light standards, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow. All Elite Series Fog Lamps are available in a cool white or selective yellow output color.
The white is a 6000K color temperature, which is a true cool white output. This will perfectly match other LEDs on your vehicle, such as DRLs or running lights. The white option also offers a premium BMW-style color band at the very top of the beam pattern.
The selective yellow option is 3000K in color temperature, which is great for high contrast in inclement weather, or in providing a distinctive look on the road. The yellow lamp consists of a yellow multi-die LED emitter paired with a yellow-tinted lens, to provide unmatched output and optical efficiency, even with the intense yellow output.
Backlight Functionality. All Elite Series Fog Lamps come standard with an integrated amber accent light. This backlight feature fully illuminates the main lens with amber LEDs, intended to match other position, sidemarker, or corner lights on your vehicle. This feature can be wired to any constant 12-volt source for your desired vehicle function, using the included tap connector. It will shut off automatically if the main beam is activated. Check local laws and regulations for acceptable use.
Bolt-On Fitment. Elite Series Fog Lamps can be installed on most vehicles in minutes. Simply remove your factory fog light assembly and ours will bolt right in its place, using sturdy glass-fiber-reinforced brackets. With built-in adjustment, the lamps can be aimed after installation. To wire them up, a pair of waterproof plug-and-play adapters are included to connect the lights to your factory bulb sockets.
In the Box:
- Two (2) Elite Series Type B fog lamps
- Two (2) H11 4-pin DT backlight tap wires
- Two (2) T-taps
- Mounting guide
Note: This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
Click HERE to shop Elite Series Fog Lamps for Toyota!
Proven Reliability - Backed for 8 Years. Like our popular Stage Series lineup, Elite Series LED lamps have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components on your vehicle. With integrated moisture-proof vents, the lamps can “breath” with changes in temperature, maintaining a strong seal over time. And with built-in circuit protection for voltage spikes and reverse polarity, these lights will keep working for years. They are backed by an industry-leading 8 year limited warranty.
Assembled with Quality - in the USA. Elite Series Fog Lamps are assembled in the USA using OEM-grade materials, including a precision aluminum casting, UV-coated outer lens, copper-core circuit board, and multi-die automotive emitters. After being assembled by Diode Dynamics in St. Louis, Missouri, they are robotically sealed with urethane epoxy for long-lasting protection against moisture, and packaged in form-fit foam for safe transportation. No expense has been spared, from materials to assembly, right here in America.
Note: All US forum members are eligible for a FREE shipping code! Just send us a direct message.
John C.
Diode Dynamics
Sponsor
Sponsor
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Sponsor
ALERT: LAST CHANCE TO SAVE 15% OFF!!!
COUPON CODE:
JULY4
Plus, all orders over $300 will receive free US shipping!
Don’t wait...this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes.
Sponsor
Sponsor
Our Labor Day Sale starts NOW! Today through Friday, 9/9/2022, save 15% on all LED upgrades by entering coupon code "LABOR22" at checkout!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Sponsor
Here at Diode Dynamics, we take pride in designing SAE-compliant fog lamps for legal on-road use!
If you've installed our Elite Series Fog Lamps or an SS3 Fog Light Kit, properly aiming your new lights is essential for optimal performance, respecting the vision of other drivers, and general road legality.
Sponsor
How do the Diode Dynamics Elite Series Fog Lamps stack up against other options on the market?
We'll have a YouTube shootout video coming soon.
Click HERE to check out the Diode Dynamics Official YouTube channel!
Sponsor
Our Black Friday Sale is LIVE! 🚨 Visit the website for our BIGGEST savings ever!
➡ 20% OFF Sitewide
➡ 30% OFF Stage Series Single-Row Lightbars
➡ 15% OFF Elite Series Headlights
➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Sponsor
➡ 20% OFF Sitewide
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
➡ Hitch Mount LED Pods (Includes free US shipping)
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Sponsor
Today, we are answering one of our most-asked questions!
In this video, we compare our Elite Series Fog Lamps to other market-leading fog lamps! We break down each fog lamp by intensity, beam pattern, color temperature, and price. For this comparison, we've used our state-of-the-art Goniophotometer, a device that measures multiple points to calculate the intensity and map out the beam pattern of each fog lamp!
We've also used our integrating sphere, which is a device that is used to measure the color temperature of each fog lamp. We hope the data we collected helps you choose the best fog lamp for your vehicle!
If you have any questions about our Elite Series Fog Lamps, email us at contact@diodedynamics.com, or give us a call at 314-205-3033 M-F 9am-5pm CST.
Sponsor
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
Sponsor
⌛THE CLOCK IS TICKING... ⌛
NOW is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
➡ Up to 15% OFF LED Lighting Upgrades
CLICK HERE TO SHOP NOW
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Did you know?
Sponsor
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
➡ 10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Sponsor
[MEDIA=youtube]9mbEheOtrpU[/MEDIA]
⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳
➡ FREE US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
Diode Dynamics
Diode Dynamics
10
05-25-2023 11:48 AM
Diode Dynamics
Diode Dynamics
20
11-29-2022 09:22 AM
Diode Dynamics
Diode Dynamics
21
11-29-2022 09:21 AM
Diode Dynamics
Diode Dynamics
18
11-29-2022 09:18 AM
Diode Dynamics
Diode Dynamics
14
06-30-2022 09:15 AM
