Attention Tacoma/4Runner: Last chance for Alloy USA Chromoly Rear Axle Shafts
Old 02-09-2012, 07:41 AM
BigMike's Avatar
Attention Tacoma and 4Runner owners! We recently came across a small quantity of brand-new Alloy USA 4340 Chromoly Rear Axle shafts, the very same shafts we used to carry a few years ago before Alloy USA stopped producing them. We had great success with these shafts, so much so that both Marlin and BigMike run them in their personal rigs. If you missed the opportunity to grab these in the past, now is your last chance -- once they are gone, they're gone!
Priced to move at just $175/pair. These may very well be the only remaining brand new Alloy USA Tacoma/4Runner shafts on the planet!
Click here for more info: http://www.marlincrawler.com/axle/re...oly-rear-axles
Old 02-09-2012, 10:00 AM
BigMike's Avatar
These axles may be used in a ABS housing so long as the following two conditions are met:
1) You have disabled your ABS system (these axles are not machined/compatible with the ABS reluctor ring).
2) You have made a sleeve/adapter to run non-ABS rear axle seals, which have a different outer & inner diameter.
Here is an adapter I machined for use in my rear ABS Tacoma axle housing that I am running on my 1981 Hilux:
Now I am able to use our Heavy Duty rear axle EcoSeals with these Tacoma Chromoly axle shafts in my ABS Tacoma rear axle housing
Regards,
BigMike
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Attention Tacoma/4Runner: Last chance for Alloy USA Chromoly Rear Axle Shafts
