93-98 T100s (Build-Up Section) Post your build-ups here
Mikes T100 Build Thread
Old 11-28-2013, 04:37 AM
  #61
FinishThaGame's Avatar
Awesome Mike, you are a man after my own heart, i did some small game hunting this past weekend and gonna be hog hunting this Fri-Sun.
I would love to do some hunting up there in WV.
Btw, how does that thing ride off road on those trails?
Old 11-28-2013, 05:50 AM
  #62
Toyota~Boy's Avatar
Originally Posted by FinishThaGame
Awesome Mike, you are a man after my own heart, i did some small game hunting this past weekend and gonna be hog hunting this Fri-Sun. I would love to do some hunting up there in WV. Btw, how does that thing ride off road on those trails?
other then street tread tires it's no different then my 93. It goes pretty good. It'd go real good if I had some M/T's on it.
Old 11-28-2013, 05:54 AM
  #63
Are the shocks stock?
Old 11-28-2013, 05:57 AM
  #64
Toyota~Boy's Avatar
The entire truck is stock
Old 11-28-2013, 06:17 AM
  #65
Gotcha. You have another Yota dont you?
Old 11-28-2013, 06:52 AM
  #66
Toyota~Boy's Avatar
i have a 87 model. But I can't drive it. It's awaiting a SAS.
Old 11-28-2013, 08:59 AM
  #67
Yeah, i couldnt remember.
Have you done a vaccum check on your T100?
Old 11-29-2013, 03:50 PM
  #68
Toyota~Boy's Avatar
We'll after having a new fuel pump for over a week now I decided to install it. I tell you what. It's a real pain on these T100's. You can't just remove the bed to install a fuel pump. The fuel tank sets up under the extended part of my cab so the fuel tank must be dropped to access the fuel pump. This is not easy when your tank is completely full of gas. Anyhow I secured the tank with a floor jack then undid the two bolts that secure the fuel tank straps. Then lowered it down. Removing the fuel pump and installing the new one was easy. However reinstalling the tank was hard. I just couldn't balance it on my jack so I man handled it. Was installed my truck started right up as normal. I let it set and idle until temperature reach normal then I revved the engine a time or two and proceeded to test drive. I immediately felt a difference. Throttle response was instantly and the power difference was insane. So I drove it down the road until I hit the freeway. Once on the freeway I was changing gears like a mad man. The RPM's were jumping up so quick. I hit 100MPH in 4th before I realized how fast I was going. I have know hesitations and the truck starts every time without any problems now.
Upon inspection of the old fuel pump I could tell that it had recently been replaced however it was a AirTex or Air Junk in my words. I installed a factory Denso like what should had been in it. The old sock was just a little filthy but not like I had expected for a 20 year old vehicle. The tank was surprisingly clean considering we're this truck has spent its life. I did notice that the fuel pump mounting bracket was a little rusty and the main fuel line was in rough shape. So that will be on my agenda to replace come spring time. It's not leaking now so it's not getting replaced anytime soon. That thing is expensive, or it is for my old 93 mini truck.
Sorry know pics as I been trying to deer hunt as much as possible due to his being my only week off from work. I'm still legal to hunt 1 buck and 3 doe so I'm hoping to knock those numbers down tomorrow so all my tags will be filled.
Stay tuned as I may take some pictures as I am hunting tomorrow as well as some of my truck on the terrain that I travel to get back in the hills to we're I hunt.
Old 11-29-2013, 04:05 PM
  #69
Dude im really happy for you, its such a relief when you go through the effort and money to replace something and it ACTUALLY FIXES THE PROBLEM!!! You must be relieaved.
Old 11-29-2013, 04:08 PM
  #70
Toyota~Boy's Avatar
yeah majorly. I was starting to doubt that the fuel pump was my issue
Old 11-29-2013, 04:16 PM
  #71
Good thing you went with your gut...
Old 12-02-2013, 03:32 PM
  #72
Toyota~Boy's Avatar
I learnt somthing new today. My T100 shuts down at 105 mph. That's pretty fast for a t100.
Old 12-02-2013, 06:28 PM
  #73
That is fast, now im curious how fast my truck will go.
Old 12-03-2013, 05:08 AM
  #74
93Xtra-Cab's Avatar
I've had mine up to 80. That was scary enough
Old 12-03-2013, 06:54 AM
  #75
CJM
CJM's Avatar
I regularly do 85mph, no issues.
Old 12-03-2013, 06:56 AM
  #76
Kytowboater's Avatar
Why? I normally don't go that fast, I stay at 70 at the fastest to keep rpms down.
Old 12-03-2013, 10:41 AM
  #77
Toyota~Boy's Avatar
I was just curious to what it would do. But yeah that's fast
Old 12-04-2013, 07:16 AM
  #78
Toyota~Boy's Avatar
I filled my truck up this morning and drove exactly 80 miles using roughly 1/4 tank of fuel. After doing the math I'm roughly getting 14 miles to a gallon. I gotta get some oxygen sensors and manual hubs
Old 12-04-2013, 07:27 AM
  #79
I get roughly 14 mpg in my truck also, it sucks...
Old 12-04-2013, 10:36 AM
  #80
93Xtra-Cab's Avatar
I just don't like my truck screaming at high rpms for such a long period of time.
Quick Reply: Mikes T100 Build Thread
