MKtaco_98's 1998 Tacoma Build-Up Thread
Old 03-18-2021, 08:16 AM
  #321
dark_fairytales's Avatar
Originally Posted by space-junk
well, im waiting on tires, mike is waiting on.............not being lazy, keith is waiting on...........not being lazy, and matt is ready. :
Lazy? I workout five days a week after work for two hours, I have been painting my bathroom and I am anal when it comes to painting; also, I have been working through the garage to make the space more then usable. Lazy?
The following users liked this post:
Mk_98 (03-18-2021)
Old 03-18-2021, 08:21 AM
  #322
MaK92-4RnR's Avatar
I was just waiting on my Biden Bucks to order everything I need to get Charlie smogged.
Mk_98 (03-18-2021)
Old 03-18-2021, 09:44 AM
  #323
space-junk's Avatar
Lazy in the aspect of getting your truck going.
Old 03-18-2021, 10:21 AM
  #324
MaK92-4RnR's Avatar
in his defense, i'd be irritated too if i built a motor and then it blew.
Old 03-18-2021, 10:42 AM
  #325
The engine did not blow, it still runs great; just with what sounds like rod knock. Speaking of rod knock, I did think recently that the sound could also be related to a piston taping a valve, which would be awesome if that is the case.
Old 03-18-2021, 11:00 AM
  #326
MaK92-4RnR's Avatar
It's pretty easy to work on the 22re. I have a non-ac single cab now and i can grab both motor mounts with my hands. Even the bellhousing bolts are visible under the hood
Old 03-18-2021, 12:18 PM
  #327
Mk_98's Avatar
I don't think it would be running good if the valve and piston are coming into contact usually means stuck valves or timing is out not to mention the lack of compression on the cylinder.
Old 03-18-2021, 01:23 PM
  #328
space-junk's Avatar
well, if you think that might be the issue, start there. compression test it. if you have low compression, you know your problem. get a bore scope and scope the cylinders to see if theres any scoring on the piston face. also, if theres a bad bearing, you should be able to see the metal in the filter media, have you torn your filter apart and looked yet?
Old 03-18-2021, 03:10 PM
  #329
High compression piston could contact and if the contact is light there would only be marks on the piston face. compression is spot on and I have not pulled the filter or done any work to since I parked it. Either way the engine must come apart. I is a nice thought if it is not a bearing
Old 03-19-2021, 07:45 AM
  #330
space-junk's Avatar
not necessarily, keith. if the contact from valve to piston is light enough and no damage has been done, you could probably do what i did and get a thick cometic MLS head gasket and ARP studs. you wouldnt need to tear into the guts of the motor then. id get a borescope and check it out, because that something we could knock out in a day in your driveway, not the garage.
Old 03-19-2021, 07:52 AM
  #331
space-junk's Avatar
@Mk_98 , wheres the new build thread with the pics?
Old 03-19-2021, 08:06 AM
  #332
Mk_98's Avatar
Mk_98 Build Thread Im still working on it trying to find all the pictures and put them in the order by date but this is as far as ive gotten
MaK92-4RnR (03-19-2021)
scuba
798
02-26-2017 03:46 PM
CodyX36
151
06-23-2015 05:33 PM
1980 4x4
12-15-2012 01:36 PM
ADH8796
08-05-2007 07:40 PM
Quick Reply: MKtaco_98's 1998 Tacoma Build-Up Thread
