Turbo 99 4Runner Pics - 5vz-fe
Old 05-03-2007, 12:14 PM
Greedy's Avatar
Hello,
After a year and a half of installing, tweaking, and tuning I finally have my turbo 4runner up and running near perfect (the tune can always be a little better right ). This started out as a project to create a completley bolt on kit for 3rd gen 4runners and taco's, but due to the vast differences year to year it turns out that the kit was never realized. However, the shop who fabricated the manifold and other piping is fabricating and installing turbo set-ups on an individual basis.
Anyways, here are some pics of how the motor turned out! I have not dyno'd the current set-up (new turbo, ported manifold, new downpipe, new engine managment etc..), but the old one put down 272 hp and 379 TQ at 7 lbs of boost. I am currently running about 10 lbs and will be heading to the dyno is a couple weeks!
Old 05-03-2007, 12:19 PM
aviator's Avatar
oooooo shiney!
looks good how does it drive? MPG?
Old 05-03-2007, 12:28 PM
Greedy's Avatar
Drives just like stock untill you decide to get going. The new turbo I got (big t3/t4 ball bearing) has almost no lag and feels alot like the S/C is terms of responsivness. My MPG is so-so, 16-18 but that's partly because I have a pretty heavy foot....
Old 05-03-2007, 03:14 PM
alexe's Avatar
did you convert to a map?
Old 05-03-2007, 03:19 PM
norcalsvx's Avatar
nice once you go turbo you never go back
Old 05-03-2007, 03:21 PM
Greedy's Avatar
No - the MAF is mounted in the charge piping between the intercooler and the throttle body (last picture is a close up of the mounting). Works good - I have a MAF clamp that clamps the max voltage to avoid throwing a CEL under high boost.
Old 05-03-2007, 03:23 PM
Greedy's Avatar
Yeah - There is no comparison to the power and tq when I had my S/C on there, the turbo is wayyy stronger. However, Mark (midiwall) here on the forum has the trd S/C and many other mods that has the potential of out performing my set-up. We will find out soon though!
Old 05-03-2007, 03:32 PM
neliconcept's Avatar
very nice
I plan on doing a TC to mine but instead of having to change out the exhaust manifold we are going to do a rear exhaust turbo setup with arb safari snorkel as the main air induction and a top mount intercooler and a HTC or holsel turbo. thinkin about the to4b .58 ar as well.
Old 05-03-2007, 03:45 PM
alexe's Avatar
ah ok a blow through setup. i was gonna say if your still using maf you should try recirculating the blow off valve but nevermind heh.
looks like a nice setup. around what rpms do you get full spool?
Old 05-03-2007, 03:51 PM
alexe's Avatar
Originally Posted by neliconcept
very nice
its your truck but personally i would stay away from a rear ehxaust mounted turbo. generally dont work very well. loose too much heat from the ehxaust which decreases turbo efficiency as well as longer piping which has negative effects to turbo spool. but then i've no experience with that setup this is just what im told
Old 05-03-2007, 04:04 PM
Greedy's Avatar
Full spool on this turbo is around 2300-2500 rpms - with the old turbo I had (standard bearing T4) it was around 3000-3200. This smaller turbo gives me alot more driveable power and does not seem to be losing me any at the top (we will see soon for sure!)
Gregg
Old 05-03-2007, 04:10 PM
Greedy's Avatar
very nice
Sounds like a modified STS set-up? I too have not heard great things about them but have never personally driven or even seen one in person. Who knows, could be a great kit! Just the fact that you don't have to take off the manifolds scores points in my book....
To4B .53 a/r turbine is similar in size to mine actually - I have a t3 .63 a/r turbine and a t04E .55 A/R compressor side.
Good luck!
Old 05-03-2007, 04:28 PM
QSVeilside's Avatar
That about sums it up!
Old 05-03-2007, 05:46 PM
coldwiz's Avatar
Yeah, what QSVeilside said! So what are the fittings and tubing going to the plenum and do you have any pics of the IC mount? How much did you have to modify to mount it?
Old 05-03-2007, 06:56 PM
Greedy's Avatar
The fittings in the runners of the plenum are vacuum/boost taps for the following:
Wastegate acuator
Electronic Boost Controller
Blow Off Valve
Additional Injector Controller
Boost Gauge
MAP-ECU2
Here is a pic of the FMIC. The only modification was enlarging a gap on either side of the radiator to let the piping fit through.
Old 05-03-2007, 07:06 PM
xcmountain80's Avatar
THat is badass!
Aaron
Old 05-03-2007, 07:07 PM
coldwiz's Avatar
Can't wait to see the new dyno numbers - keep us posted
Old 05-03-2007, 07:27 PM
YodaPala's Avatar
Um, I cant explain how badass this it you the man!!!!!!!!!!!
Old 05-03-2007, 07:33 PM
90RunnerRed's Avatar
Any guess at what kind of numbers you're gonna get?
Old 05-03-2007, 07:34 PM
Greedy's Avatar
Thanks for the compliments. We will see how badass it all is once I get on the dyno. It has been alot of work and trial and error with different parts and configurations. I BETTER be breaking 300 hp to the wheels or else!!
Quick Reply: Turbo 99 4Runner Pics - 5vz-fe
