Transmission won't hold in any gear
the one shift in a transmission that is all mechanical, is shift to 1st gear
it is a guarantee...so your problem might actually be very simple
something broke or snapped or a linkage is messed up
Thanks for the input. I wired up this swap myself, so another guy in the 3.4 swap section suggested some wiring to look at. After looking over my adapter harness I didn't wire up the L and 2 on the transmission to ECU. It's an electronically controlled transmission and L and 2 have their own positions in the ECU plug at e12-1 and e12-10. The linkage is all good, but apparently it needs ECU input to hold in 1st or 2nd. I'll try to report back, but it's looking electrical, and something I caused.
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
