torquing lower balljoint castle nut
Out of curiosity, what is the proper procedure once proper torque is met?
Do you over tighten to get the cotter pin in, or do you back it off?
I know what I did, but I don't know if it was right. I also replace mine a month ago. I really should have checked when I did it...
And to respond to the original question, I did not have the issue you did with the stud turning. I did have it bolted to the knuckle and a jack lightly raising the a-arm to help the upper and tie rod stud go into their proper positions.
I just slightly over torqued the nut to fit the cotter pin. Trying to back it off just made it break free and got very annoying. Also realized that over-torqued is better than under-torqued equaling a stronger hold. And yeah, I didn't gorilla tighten the nut to were the bolt can snap. just a "slight" over torque
I just asked the same question on another forum, and most people say overtorque. I agree with that, but not because it gives a "stronger hold" because it doesn't. The little overtorquing I did to get the cotter in didn't feel like a big deal.
And by the way, the stud will not snap if you overtorque it, it is a heat treated part. The nut will strip. The nut is a softer metal and designed to be the failure point in case of overtorquing. This is why I always advise against just getting grade 10 bolts to replace toyota bolts. Sometimes softer metals are chosen for a reason. Not always, but sometimes.
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
