Timing belt woes
Old 01-07-2013, 06:01 PM
bend's Avatar
Timing belt woes
Doing my timing belt and the right cam moved a significant amount. What do I do?
Old 01-07-2013, 06:06 PM
rworegon's Avatar
What engine are you working on?
If you are working on the '88 4Runner, you posted in the wrong forum.
Edit: I see the 3.4 in you sig line. Too much speed reading.
Old 01-07-2013, 06:09 PM
rworegon's Avatar
Anywho, the 3vze 3.0 and the 5vze 3.4 are both non-interference engines so you can rotate the cams with no problem....go clockwise and align it to the TDC mark.
Old 01-07-2013, 06:17 PM
bend's Avatar
Sorry. 3.4 swapped into an 88. Wouldnt one rotation put it in the wrong stroke?
Old 01-07-2013, 06:22 PM
rworegon's Avatar
Ah, 3.4....
When the cams are at TDC marks and the crank is at TDC you are good to go so says the FSM and experience.
A excellent how-to from a member here:
http://home.centurytel.net/stevenjac...lt/timing.html
I found the thread where Philtog had the same question:
https://www.yotatech.com/forums/f120...ng-tdc-240866/
Old 01-07-2013, 06:27 PM
bend's Avatar
Okay. Anybody else have input? I am extremely nervous. I know this is a noninterference engine but I dont want to mess up.
Old 01-07-2013, 06:43 PM
bend's Avatar
I think you are right rworegon. I looked at a million different threads and they said the same thing. I'll let you know in a little while.
Old 01-07-2013, 06:48 PM
rworegon's Avatar
BTW, use a new crank bolt (it's a non-reusable part per the FSM) from the dealer and torque it to 217 ft-lbs per spec.
Old 01-07-2013, 06:53 PM
rworegon's Avatar
Post #24 gives the TB procedure. Page EM-19, step 6 is what you are inquiring about:
http://www.ultimateyota.com/index.ph...&topic=7462.15
Then EM-21, step 10 is the check after the belt is on.
Old 01-07-2013, 07:06 PM
1blink's Avatar
just turn the cam clockwise back around to it's timing mark again, no harm done. I had the same thing happen during my timing belt job a few weeks ago. I think spring tension makes the cam pulleys prone jump off the mark if moved slightly. As long as all 3 pulleys are back on their timing marks when the belt goes on, you are ok.
Old 01-08-2013, 08:29 AM
bend's Avatar
Well now it starts but dies after a couple of seconds. This sucks.
Old 01-08-2013, 08:41 AM
1blink's Avatar
I bet you broke a tooth off the crank timing pulley. Read my thread:
https://www.yotatech.com/forums/f2/ignitor-failure-261749/
Old 01-08-2013, 08:49 AM
bend's Avatar
Well now it wont even crank. Just clicks. Battery voltage seems good at 12.45. I dont know what to do.
Old 01-08-2013, 09:01 AM
1blink's Avatar
Does it not even turn the starter?
Old 01-08-2013, 09:07 AM
bend's Avatar
So I forgot to plug an ignitor pack plug back in. Then it wouldnt crank. So I take the positive leads off the battery and make sure my starter wires are tight. Then hooked the battery back up and it starts! no issues. Thank God.
Old 01-08-2013, 04:19 PM
rworegon's Avatar
Nice! Enjoy your handiwork.
Old 01-08-2013, 05:20 PM
98SR54RUNNER's Avatar
Originally Posted by rworegon
Ah, 3.4....
That writeup is great. I used the same one when doing timing work recently during motor swap. And yeah, cams moved some before we got them all aligned and belt setup perfectly. It was surprisingly easy though.
I'm glad you figured it out!
Eggslinger
06-08-2019 03:32 PM
thefishguy77
07-30-2015 10:59 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Timing belt woes
