Texas_Ace's Cheap DIY Meth/Water Injection kit Writeup! Get 10hp+ for under $150!
Old 02-27-2015, 11:03 AM
  #241
ETRNL's Avatar
so i just got my devils own stage 2 voltage in yesterday and waiting till monday to install it at work. i am still trying to source a low level float. any recommendations on a small compact one that i can pick up at a parts store? all the auto stores can only look it up by year/ make /model...
Old 02-27-2015, 11:07 AM
  #242
vasinvictor's Avatar
http://www.coolingmist.com/detailmain.aspx?pid=float01 is the one I use. Not sure about one to source from a part store. Sounds like you are wanting one in a hurry?
Old 02-27-2015, 11:40 AM
  #243
ETRNL's Avatar
not necessarily in a hurry, just common and readily available.
Old 02-27-2015, 12:01 PM
  #244
Texas_Ace's Avatar
Search ebay for water level switch, they can generally be found pretty cheap.
Old 12-23-2015, 08:31 PM
  #245
ETRNL's Avatar
i must say i am happy with the kit so far. i average a lil under 2 gal of washer fluid per tank of fuel. so far only problem i have had is the line fitting that is for the tank tap ,for lack of better words, went out. as in it no longer held the line into the tank and dumped all my fluid. a few zipties later and the temp fix is holding just fine.
Old 10-20-2018, 11:49 AM
  #246
aa1911's Avatar
well whatya know, after 8 years or so running alky injection, all of my controllers have bit the dust. I have 3 Devils Own 0-5v controllers and the last one gave up the ghost, it goes into fault mode as soon as activated and does something to the maf sensor that cuts fuel completely, the truck jerks until you let off. I plan to contact D.O. and see if I can send them back all 3 for one working one in return at least. They are in perfect condition, no damage, physical, water or otherwise, they all just quit one by one.
So I just ordered the $30 boost switch in the first post on this thread, hopefully it works well enough for me. Still running the blower although I just got a new reman engine put in this summer so still need to tune, I'm chasing CEL gremlins like a son of a gun. But the bum controller was not helping anything, just gave me P0171 codes (lean) and I have a persistent P0125 code. But one thing at a time....
I'll run the same D.O. sureflow pump and nozzle (I still love their nozzles) but not a huge fan of the controllers right now. AEM controller is about the same price, I might end up with one of those but if the DIY one works then I'll be happy.
Old 10-20-2018, 12:00 PM
  #247
aa1911's Avatar
I noticed D.O. website has the same exact pressure switch as you posted Texas Ace, same exact price. They have 3 different PSI range options also.
4x4-runner
04-18-2017 09:08 PM
tj884Rdlx
08-28-2015 12:04 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Texas_Ace's Cheap DIY Meth/Water Injection kit Writeup! Get 10hp+ for under $150!
