Supercharged 5VZ Hard Starting?
Old 01-26-2010, 06:32 PM
chris360hawks's Avatar
I just installed my supercharger about a month ago along with Supra injectors, IK22 plugs and a unichip tuner. My truck currently has about 185k miles and it has been meticulously maintained by me and the previous owner. The truck seems to run great with the supercharger and associated tuning. No pinging under load. However once in a blue moon (1 out of every 40 starts or so) after the truck has been turned off for 45 mins or so and I go to start it, it misses and dies. When I go to crank it again I will tap the gas and it will start and rev fine. Everything is then back to normal. Why does it do this? Any ideas? I should also ad that I haven't noticed any coolant or oil loss or discoloration.
Old 01-26-2010, 08:05 PM
okie81's Avatar
First off, check your spark plug gap. IK22's tend to vary out of the box.
Old 01-27-2010, 05:11 AM
Should be set at .043" correct?
Old 01-27-2010, 05:34 AM
mt_goat's Avatar
What A/F ratio are you getting?
Old 01-27-2010, 07:12 AM
hross14's Avatar
Sensors--TPS and etc.....but if it makes you feel better...mine does this in a blue moon also. Usually after heat soaking on a hot day.
Old 01-27-2010, 03:41 PM
Is yours supercharged too? you should come down to SA sometime and wheel. Lots of yota guys down here.
Old 01-28-2010, 11:41 AM
hross14's Avatar
No, no SC--looking to put one on soon though--
I make my rounds--usually with the Krawltex group outta North Austin. We are a mix of rigs.
Like i said though--i would start going over all the little sensors and such. Personally, i wouldnt bother unless it got worse......
I say TPS because it causes odd problems as it gets old--so maybe it is heat soaking and causing your issue. Or maybe a leaky injector or 7th injector?
Old 01-28-2010, 01:28 PM
I have the Supra injectors. A couple orings got ripped on install so they were leaking, but those have been replaced. I will check my gap soon. I know that I remember bending the center on one of the plugs on the IK22s when i was gapping it so maybe that is it.
Old 01-28-2010, 01:35 PM
hross14's Avatar
No, I mean are the injectors leaking fuel? How many miles on the TPS and associated sensors? Fuel pressure regulator?
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
coryc85
07-06-2015 04:07 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Supercharged 5VZ Hard Starting?
