seat bolt ripped out
Old 10-10-2008, 02:33 PM
312necro213's Avatar
happened to me to, did the same thing with washers cost me like 10$ total or something, and a lot more piece of mind because i did it to all the others too after i saw that. haha 4wheeling plus cheap seat mounts don't work well together.
Old 06-04-2009, 06:41 PM
alteredvision's Avatar
Same here, is there a recall from Toyota? I have a '96 4Runner Limited. Same left bolt on driver seat.
Old 06-04-2009, 06:47 PM
Elton's Avatar
the mounting point in the front is very weak
Old 06-04-2009, 06:59 PM
RMA
RMA's Avatar
WoW!! I cant believe this many people have had this problem.
I have never seen this happen to any of the trucks ive had or sold.
Old 03-01-2010, 11:58 AM
  #25
98SR54RUNNER's Avatar
I attempted to fix this problem with mine several months ago, and the washers weren't big enough, they just made the hole a little larger. I tried using some wing-type washers that are spring-loaded, and they didn't last much longer.
Can anyone that has had success fixing this shed some light on how you fixed this more permanently?
If the washers are big enough to hold the bolt from ripping through the bottom side, how do you even get them through the hole?
TIA
Old 03-01-2010, 01:08 PM
  #26
Midget96's Avatar
First, I used a screwdriver and a hammer to put a reference point on the floor pan; hold the screwdriver as vertical as you can through the torn out bolt hole and whack a nice dent into the floor. Underneath the truck, you'll see the dent and the spot weld marks where that raised panel holds the blind nut that tore out.
I used a hole saw and bored a hole into raised front nut mounting rail. Put a big ass washer and a nylock nut in there, fed the bolt through and tightened. Sealed it up with some silicone and a simpler metal plug easily found at Ace. Only downside is you have to remove the plug to get the seat out, but after doing that 8 months after the initial repair, I found my patch was weather tight.
Old 03-01-2010, 01:33 PM
  #27
Fink's Avatar
Seen this happen many times on here - same fix everytime.
The best thing to do, which I think somebody brought up on here, is to cut all that old metal out and weld a new piece in.
Another option would be to just get a piece of thick sheet metal that was 3-4x larger than the mounting hole and use that as a "washer."
Either way, hope that holds up for ya - may consider going around and beefing up the other bolts on your seats too.
Fink
Old 03-01-2010, 02:06 PM
  #28
Elton's Avatar
my fix has been working just fine
Old 03-01-2010, 06:21 PM
  #29
aowRS's Avatar
Your repair bolt needs to go through the bottom pan of the truck as well...
Andreas
Old 03-02-2010, 09:33 AM
  #30
Thank you for the details!
Old 03-03-2010, 04:11 PM
  #31
ChildrenOfBodom's Avatar
when this happened to me, I ziptied it with like 5 huge ones but yeah it's really not a good idea.
Cut and a weld a new piece in, you want it to hold if you get in a crash. I will have to get on this when I have welder access. better safe than sorry
Old 03-07-2010, 08:05 PM
  #32
pendrag's Avatar
Good grief - has anyone told Toyota about this one? A crash puts a heck of a lot more stress on the attachment point than stopping at a light.
Old 03-07-2010, 11:26 PM
  #33
Cal01's Avatar
what the (whozus)! guess i have to be gentle with my belt now
Old 08-04-2010, 10:36 AM
  #34
pdyebrasil's Avatar
Just had this happen to me too... I guess after almost 201,000 miles of abuse it just gave up. Strange though; On my rig it was the right side that gave way. That's while sitting in the seat facing forward.
Old 08-04-2010, 05:53 PM
  #35
Ironmike4x4's Avatar
Originally Posted by Farmerunner
Elton,
I had the same thing happen to me. My 99 had around 200 000 miles on it at the time. As I recall, it wasn't even a rusting issue, the bolt (and it was the on on the left), just ripped out of the floor. I am a big guy though, at 220 lbs, that might have had something to do with it!
What I did was drill a hole right through the floor and attached the seat with a carriage bolt, putting a large washer on the bottom side.
It has been like that for well over a year and I don't notice any down side to this. It should be stronger then stock, from what I can see. It is really a quick and easy fix. If you want pictures, I can send them.
Adam
Ditto mine did the same about 3 months ago. At least it cured the god awful squeaking my seat was having on rough roads. I thought it was actually in the seat back frame not the mounting holes. Oddly enough I didn't discover mine was broken until I was taking the seats out to steam clean the carpets.
Old 12-02-2023, 08:09 AM
  #36
SWitek's Avatar
This just happened to me on my '99 Limited. Anyone who has done the floorboard fix remember how long the new bolt needs to be?
jasonty
41
12-23-2018 01:00 PM
Esibnitsud
07-30-2015 08:19 PM
noahstancik
07-17-2015 05:38 PM
jetspeedz
07-13-2015 09:32 PM
icentropy
07-09-2015 02:12 PM
Quick Reply: seat bolt ripped out
