SEAFOAM and Superchargers
Old 11-04-2004, 11:21 AM
Amir904's Avatar
i gota do this soon....
Old 11-04-2004, 11:27 AM
bamachem's Avatar
https://www.yotatech.com/forums/show...982#post442982
Old 11-05-2004, 11:58 AM
h7009's Avatar
re: seafoam
Hey thanks Bamachem, I just did this in front of my work place, follwed the instructions right off the can, couldn't figure out where the blasted PCV was so put it in the brake booster line, worked fine, just poured slow, waited 10 minutes, white smoke, lots of white smoke. let it sit about 10 minutes did it again, not as much smoke. Put a full can in the tank and filled her up. we'll see what the mileage is, going on a road trip to the UP to deer hunt soon, thanks for all the great advice and help here. EDH
Old 07-17-2005, 06:13 PM
northfacer581's Avatar
after reading the 17 page thread, and this one, i think ive figured out the seafoam might be giving me a bang for the buck. all the pictures ive looked at are red x's. if anyone could post one of the 3.4L with a big circle around which hose im supposed to pour down, thatd be great. im not too good under the hood. i just know all about the electronics and audio stuff. also, does it matter how full ur gas tank is when you put the seafoam in?
Old 07-17-2005, 10:38 PM
  #25
marko3xl3's Avatar
Here you go northfacer . Good luck with the seafoamin'. I know my engine doesn't have the S/C, but since people said the brake booster hose will work, these pictures should help you just fine.
Pic #1 = PCV Hose
Pic #2 = Brake Booster Hose
Old 07-19-2005, 05:30 AM
  #26
MTL_4runner's Avatar
Originally Posted by Mohamed
Travis, use the brake booster line, that's what I use, go to home depot and get a small section of 3/8" thick PVC clear tubing, when the celica is all nice and warmed up (in fact take that to Home depot) disconnect the brake booster line and make sure you hold on to the tube and dip in and out in the can real quickly, let the car sort of stabilize before you dip the tube back in the can, otherwise you'll hyrdolock too quickly and not get the full benefit. If that happens, just let the car be for five minutes and restart, and continue the process. Let it suck up about 1/3 of the can since it's a turbo then hydrolock it by leaving the tube until it sucks as much as it can and dies. Leave it for about 5-15 minute (the more you leave it in there, the more it softens up the built up carbon). I did my honda the same way and worked great!
[EDIT] Now that i think about it, you're burning carbon and I don't know if that's good for a turbo or not as it uses expelled gases to power the turbines. According to their website it's safe for all 2 and 4 cycle engines. If it was my car, would I do it....yup I would but i guess I wouldn't let it sit inside the engine too long after it hydrolocks.
I think you mean the engine just dies from an over rich condition (like giving it too much choke), not hydrolocks. Hydrolocking is when your engine ingests enough liquid to stop the pistons physically (usually major damage ensues). Just semantics but there is a very important distinction to make there.
Old 07-19-2005, 05:01 PM
  #27
Mohamed's Avatar
yeah I guess that's a better explaination...the engine does pretty much choke, it's doesn't quite hydrolock. But everytime I explain how to use it, that's what I tell them, "hydrolock"...but you're right , you're not hydrolocking until you've stuffed enough liquid into the cylinders that the liquids can't quite compress and your engine dies, literally.
Old 07-19-2005, 05:23 PM
  #28
well ive bought my seafoam, and im going to wait till tommorrow during the day to do the treatment. im going to make a video so anyone who has yet to do it will understand how it works. (my friend has done this many times, hes helping out). thanks mark for the pics!
Old 07-20-2005, 05:15 AM
  #29
..... you're not hydrolocking until you've stuffed enough liquid into the cylinders that the liquids can't quite compress and your engine dies, literally.
.... or explodes if you are reving high enough when you do it.
It's only funny when it doesn't happen to you.
Old 08-10-2005, 06:34 PM
  #30
shurick's Avatar
Any luck making that video?
Old 08-10-2005, 07:14 PM
  #31
naw our camera is busted...its in the shop. i plan on doing it again soon, and will try my best. plus i dont know how to upload a video on here...just pictures.
Old 08-21-2005, 09:21 PM
  #32
midiwall's Avatar
fwiw... I ran Seafoam through my S/C'd truck last night/today. Very noticable change in how it runs. Smoother, less bog on the bottom, nice kick over all.
I ran 1/2 can into the brake booster line and put a full can in the tank. I let it sit overnight, and blew crap out the tail for a solid minute when I started it about 12 hours later.
Old 08-22-2005, 09:45 AM
  #33
i experienced very similar results. increased my mpg and runs better, noticably different. its also a good idea to change your oil after doing this.
Steven.m.paulk
06-07-2020 10:45 AM
LCE_Performance
10-01-2015 01:03 PM
anniesball
10
09-15-2015 05:41 PM
anniesball
09-09-2015 09:55 AM
anniesball
09-07-2015 11:20 AM
Quick Reply: SEAFOAM and Superchargers
