rs3200 security system unistall
Old 07-13-2010, 09:00 AM
skjos's Avatar
Mine started, locked and unlocked before and after I installed the alarm system. I would imagine that if all these features work with your alarm system installed, they should work after you remove it. You may need to reprogram the system after the alarm is pulled, I'm sure there are threads covering the reprogramming procedure.
Old 07-13-2010, 05:44 PM
rjaudi's Avatar
Originally Posted by mkk572ny
didnt get a chance to try it over the weekend (family emergency). just wanted to check that if i did unistall it, it wouldnt mess up the car like not being able to start it, lock/unlock, etc?
I believe the key to the uninstall is removing the alarm harness completely and plugging the factory harness into the stock location. Once that harness is removed the truck should function like the alarm was never there.
Old 07-29-2010, 04:25 PM
mkk572ny's Avatar
delayed response here but it worked and is unistalled thanks to all
Old 01-28-2014, 10:47 AM
j-man's Avatar
bump for a good thread.....
coryc85
12-05-2015 08:42 AM
Obmi
11-24-2015 11:37 AM
Williamemslie
14
10-05-2015 09:28 AM
highonpottery
09-14-2015 12:46 AM
shalom
09-08-2015 10:02 PM
Quick Reply: rs3200 security system unistall
