reset 22re ECU
Old 09-22-2004, 11:51 AM
desert whomper's Avatar
reset 22re ECU
how do i reset the ECU on my 91 pick em up truck?
Old 09-22-2004, 11:54 AM
rimpainter.com's Avatar
Pull the EFI fuse or the negative battery connection for 15 minutes. Then reinstall.
Old 09-22-2004, 02:22 PM
yamarocket630's Avatar
The 22RE ECU is so basic it doesn't really have long term memory. It pretty much resets itself every time you turn the key off.
Old 12-26-2015, 06:35 PM
bdimick's Avatar
Thats so wrong I actually think you must be joking?...it remebers a lot actually, its a big reason for adding the ecu in the first place, its a brain for your car that learns and adapts to things you might never even notice are happenng. It maintains an "optimal" fuel/air ratio, timing, idle, remembers error codes and so on. All in the face of failing parts and changing conditions. It even keeps track of all the times you pick your nose while driving All things that are very helpful in keeping your yota healthy and on the road longer! You should reset your ecu after most major repares that effect engine performance, or it will actaully continue to compensate because it hasnt learned it is fixed yet, and may start running worse untill it catches up (slow developing vaccum leaks secifically in my experience). New cars just make it look like childs play in comparison but its still impressive and very helpful!
Old 12-26-2015, 06:52 PM
bdimick's Avatar
Sorry for the double post...it cut my last one off and then started this one, which i cant seem to delete now, not a fan of the mobile experience so far!
Old 12-27-2015, 12:08 AM
wyoming9's Avatar
Red face
11 year old thread in the wrong section as well
RatOmeter
10-22-2015 03:17 PM
raptor510
08-19-2015 02:15 PM
dfarr67
07-30-2015 07:08 AM
nonstop
07-24-2015 06:29 PM
Sandman
07-14-2015 12:36 PM
Quick Reply: reset 22re ECU
