removing flywheel bolts!!!!!! (arghhh)
Old 02-21-2005, 02:10 PM
TechWrench's Avatar
Well, if the bolt direction isn't an issue, then all that remains is to use one of the methods mentioned to secure the crank so it doesn't turn and use a long enough handle to overcome the bolt torque. Which brings up another point. When you get ready to put it all back together, make sure you tighten the bolt to the correct torque setting. It was initially tightened to that degree for a reason.
Old 02-21-2005, 05:29 PM
needayota's Avatar
are there torque wrenchs that go to 190 ft/lb?
i dont think mine does.
Old 02-22-2005, 04:49 AM
MTL_4runner's Avatar
Yes, but I'd just rent one instead of buying it.
Don't forget to loctite the threads when installing it.
Old 02-22-2005, 05:34 AM
needayota's Avatar
ok.
thanks for all your help man
Old 02-22-2005, 09:16 PM
  #25
p5150's Avatar
i dont think the Toyota manual recommends loctite.
Old 02-23-2005, 04:18 AM
  #26
You always want to loctite anything in a critical application (crank pulley, flywheel, brakes, etc).
There is no damage caused by doing so and it adds extra insurance that it will not come apart on accident.
Just be sure to select the correct loctite for that particular application.
Old 05-06-2019, 02:46 PM
  #27
rmjones's Avatar
Flywheel bolt thread direction
What is the direction for the removal of the Flywheel bolts for 2007 toyata hilux, every post just seems to skip that point.
Old 05-07-2019, 06:32 AM
  #28
millball's Avatar
Rightie tightie, leftie loosie. Only in certain rare instances are left hand threads ever used.
09-04-2015 09:27 AM
accuracy
08-06-2015 12:32 PM
TJWilly
07-31-2015 02:05 PM
TransAmBandit
07-28-2015 11:30 PM
KBar
07-13-2015 06:01 PM
Quick Reply: removing flywheel bolts!!!!!! (arghhh)
