Question about Supercharger on 3.4L
Old 10-05-2004, 08:22 AM
kenandjenn's Avatar
I found a truck with the TRD supercharger installed on it for sale. If installed correctly will the TRD kit still have piniging problems? I'm sure it has the 7th injectors installed. Do they always have problems unless heavily tweaked afterward?
I don't know much about the SC 3.4L
Old 10-05-2004, 08:24 AM
SLC Punk's Avatar
It all depends on where you are at (altitude), year, and gas.
Some ping, some dont.
The best advice I can give you is go to gadgets website www.gadgetonline.com
Old 10-05-2004, 08:33 AM
kenandjenn's Avatar
Alabama, so maybe 1,500 above sea level at times. Its a 2001 truck and we have good ole 93 octane here.
Old 10-05-2004, 08:38 AM
AUJWE
Guest
Posts: n/a
It may not ping too bad. Bamachem installed one on his and hasn't had much pinging(unless he has since last I read his post) and he's in Birmingham. If it has the 7th injector kit then it should not ping. That was TRD's band-aid try at fixing the problem. I would be more worried about the transmission than anything. Is it an auto?
Also, where in Bama are you? I'm guessing north part if you are 1500 ft above sea level.
Old 10-05-2004, 08:58 AM
kenandjenn's Avatar
I live around Fort Payne Al , which is about 95 miles North of Birmingham. Fort Payne is just a little above sea level like Birmingham, but I live on the Mountain and it's about 1,500 ft higher than the valley.
I was aware of the tranny problems and I knew if I got this truck it would be something to address w/ a Cooler and valve body upgrade.
Old 10-05-2004, 09:04 AM
bamachem's Avatar
I have a 99 and put one on and ONLY had pinging w/ 87 octane and when I put on a 2.2" pulley. I put the regular pulley back on and it went away again. I went ahead and put in Denso 5042 plugs and a Hayden transmission cooler to be on the safe side. I wasn't wanting to make it "faster" but I was wanting more torque to more easily pull hills with the 33's on there. I got that plus some.
In all, I'd say it's definitely a plus.
Old 10-05-2004, 09:32 AM
4RunnerFever's Avatar
I think there will always be some pinging, but determining what is normal ping and dangerous ping is the hard part (at least to me). Any pinging is worth it, however, because the supercharger is so fun :-)
Old 10-05-2004, 09:41 AM
kenandjenn's Avatar
Did you install just the standard TRD kit w/ 7th injector or did you go w/ Gadgets kit? I'm definitly not expecting a race truck, but If I ever do get a 4wd TRD then it would be nice to have the extra power to pull some larger tires.
Going from a 500 h.p. Dakota to a 150 h.p. 2.7L Tacoma is HARD to swallow... especially since I don 't even have 4x4. Having 250 h.p. from the 3.4L sure must be nice.
BTW... the owner of the truck wrote me back and said that his truck does not have the low rpm ping. He also uses 93 octane. He installed the SC at 8,000 and has had it on ever since.
Old 10-05-2004, 10:33 AM
lee
lee's Avatar
the dakota is 500 hp????
Old 10-05-2004, 10:34 AM
MTL_4runner's Avatar
I was thinking the same thing....
Old 10-05-2004, 10:45 AM
kenandjenn's Avatar
Haha... Not STOCK guys! 250 h.p. from the factory w/ the 5.9L in the Dakota R/T.
I had:
1.92/1.62 Fully ported and polished heads, 5 angle valve job, etc (275cfm intake/230cfm exhaust)
M1 2bbl Intake manifold - gasket matched to the heads
PPH 1 5/8" Tri-Y headers running into a 3.5" single spintech exhaust. NO CATS!
1.7 Harland Sharp Roller Rockers
B&G Custom PCM flash
F&B 52 MM TB (950 cfms)
K&N Gen2 (They work well on the Dakotas
MSD Digital 6 plus, MSD wires, NGK plugs- 1 step colder
180* Thermostat
NX 150 h.p. wet shot
The truck also came stock w/ 3.92 gears.
3800lb Truck ran 12.2@110 spinning badly on 28x10.5 Hoosier slicks WITHOUT The heads.
150 h.p. just ain't cuttin it. I had that much in the bed of my Dakota!
Old 10-05-2004, 10:47 AM
AUJWE
Guest
Posts: n/a
I like it up there. I live in Auburn(school) but I am from Mobile. I did some camping at DeSoto State Park earlier this Summer. Nice place.
Most folks just do the tranny cooler and are done with it. But, it definitely wouldn't hurt to do a VB upgrade.
I don't think BamaChem is using the 7th injector or the URD kit. I guess he's saying that with the normal pulley and 93 octane he has no pinging. That's good to hear.
bamachem's Avatar
Neither. I got my SC as a Dealer Trade-In takeoff w/ 8k miles. It came w/ the smaller pulleys and the 7th injector. The 7th injector adds fuel to prevent top end lean-out conditions for high speed and it adds a timing map retarder to reduce or eliminate pinging for high-gear / low-rpm cruising speeds like on the interestate. My engine NEVER sees over 4k so the 7th injector wasn't needed, so I put it up for sale and bought a TMC1.1 off of ebay to retard the timing. Once I changed to 93 octane, I didn't have any more ping, so I never needed to install that either. It's for sale if you're interested later, but w/ the 7th inj kit, it isn't necessary. I went ahead and did the cooler plugs as insurance, but now I've lost some MPG's since the swap and I'm considering going back to the regular NGK plugs.
Old 10-05-2004, 10:59 AM
SLC Punk's Avatar
It must be nice to have 93 octane there, we only have 91 in SLC.
If you do ping, one way to fix it is to install a TMC 1.1. I have a writeup on my website. Mine has not ping'ed once since I installed it.
Old 10-05-2004, 11:01 AM
SLC Punk's Avatar
So is the one you are looking at have a s/c 4 cyl?
If so, you could get more power from a stock 3.4
Old 10-05-2004, 11:02 AM
Good writeup Travis!
http://slcpunk2003.tripod.com/id15.html
Old 10-05-2004, 11:27 AM
AUJWE
Guest
Posts: n/a
How much of a difference do you think 91 vs 93 octane would make in the whole pinging battle?
Old 10-05-2004, 11:35 AM
SLC Punk's Avatar
Thanks,
So was it easy to read and understand?
Old 10-05-2004, 03:16 PM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
It made a difference for me when I moved from Denver to D.C. Running 91 in thinner, drier air and I didn't have a pinging issue. Running 93 in sea-level, humid air and it has developed the HG/LR issue. I think its a combination of all three variables that has made the issue surface.
Old 10-06-2004, 04:51 AM
bamachem's Avatar
BTW: I have a TMC1.1 on ebay NOW for $125 and NO RESERVE!
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7926219550
ChiefTetlow
08-10-2015 04:19 AM
anniesball
07-29-2015 11:46 AM
1996Taco
07-20-2015 12:02 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Question about Supercharger on 3.4L
