Once again, 3.4L Engine Noise
Old 06-09-2011, 08:26 PM
tc98sr5's Avatar
I am at Wits end! I have myself a very beautiful 98 4runner. haha. I love it to death, but right now I want to drive it off a cliff.
I have been chasing to no avail a ghost sound on the front of my motor.
I have replaced almost everything.
New Timing Belt Kit (This replaced EVERYTHING. Idler bearings, Belt, Water pump, tensioner, thermostat, everything)
New Alternator
New Power Steering Pump
New A/c Idler Pulley
The only thing I haven't replaced is my A/c Compressor. I know thats not the culprit.
Has someone out there found this problem and remedied it?
Btw, the sound is not metallic. Its more like a constant moan. On some days, it sounds like the whine of a supercharger.
Hope that helps.
Old 06-09-2011, 08:51 PM
Yota Runner's Avatar
what about your other belts...are they old...to tight...to loose...etc?
Old 06-09-2011, 10:21 PM
CodyX36's Avatar
Does the noise change as your truck accelerates?
Old 06-10-2011, 06:03 AM
tc98sr5's Avatar
Every belt on my engine is brand new OEM belts, all tightened to specs. The noise is noticeable mainly at Idle
Old 06-10-2011, 06:28 AM
Hey is your rig a 5 speed?
Old 06-10-2011, 06:34 AM
sounds like we're playing 20 questions haha
If your rig is not a 5 speed disregard that comment... However if it is a 5 speed, it is pretty common for them to make a whining noise with the truck sitting at a standstill in neutral with the clutch engaged and go away when you push in the clutch pedal....just throwing that out there
Old 06-10-2011, 08:00 AM
BajaRunner's Avatar
Mine does this as well, I assume its a belt. I do smell a burnt rubber smell after a long drive, and I'm just waiting for something bad to happen
Old 06-10-2011, 08:06 AM
rjaudi's Avatar
Did you inspect the fan bracket bearing?
Old 06-10-2011, 09:17 AM
tc98sr5's Avatar
It is a 5 speed, however it is not the throw out bearing or drivetrain related. I will have to look at the fan bearing...
Old 06-10-2011, 12:18 PM
J2F42C's Avatar
Also take a look at the fan clutch.
A $12 mechanic's stethoscope can go a long way to diagnosing mysterious sounds in an engine bay.
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Once again, 3.4L Engine Noise
