Oil pressure sending unit
Hi guys, its been a while since I posted as my 4Runner has been running great. So today I changed the oil and as I was taking off the oil filter, the wrench slipped and busted off a screw on piece right next to the oil filter. It has a spring in it and looks like a sensor of some sort. The truck runs fine and I will get it replaced ASAP, but I was wondering if anyone knew what the sensor actually does and if its ok to drive the truck in the mean time before I bring it to the dealer. Here some pics.
As always, thank you to all the great people and info on this site!! Oh yeah, Happy 4th of July!!!
Staff
I would replace it as soon as possible. It is under alot of oil pressure and if it pops a leak, it will spew oil out fast.
I was swapping one from the light to the guage and the head of the unit busted off leaving a hole right threw the center of the threads. Take your time getting it off. Make sure you get a good fit with the wrench.
Thanks guys for the replies. No lights on the dash. Most of the piece is still screwed in so I don't think there is a chance oil will come out, but I hadn't thought of that possibility before.
Mr. Ace, you think an autoparts store would stock it? I thought it may be something I could only pick up at the dealer, but I'll check around at some of the autoparts stores first. Thanks again!
I don't know if it's the same thing but...
https://www.yotatech.com/forums/f2/o...-5vzfe-247947/
Maybe it will help you out, maybe not. The plastic on mine was cracked a little and spewed oil like crazy!
Hi,
I see that this post is already a couple years old, but can someone tell me what the Toyota part number is for this oil pressure switch? I have a 2000 4Runner 3.4L. My switch has been leaking since my last oil change so I need to replace it but need the part number.
Thanks very much!!
Thanks very much!!
The following users liked this post:
LevanM (09-02-2021)
skoti89
09-11-2015 07:46 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
