Oil Light Flicker
Old 12-02-2007, 03:45 PM
wizzells's Avatar
Originally Posted by PAULUNM
It also happens when on level ground- in Drive or Reverse, but stopped. When it is in Neutral, the light goes off.
My thoughts are that it is happening when the vehicle is in gear and not in neutral because your RPMs are higher in neutral than while in gear at a stop. When the RPMs drop, the pressure drops. As the RPMs come up, so does the pressure - just like every other oil pump in the world. You may have something blocking an internal oil passage, or an oil pump problem itself. Something is probably causing a significant drop in oil pressure and if you don't know for sure what it is, DONT DRIVE IT until you have the problem diagnosed! There is a reason there is an oil pressure light!
Old 12-02-2007, 05:06 PM
ciscojay's Avatar
This is very interesting, I found this in my official Toyota 1998 4runner Owners Manual, Chapter 1-5 p.69:
"(d) Low Oil Pressure Warning Light
This light warns that the engine oil pressure is too low. If it flickers or stays on while you are driving, pull off the road to a safe place and stop the engine immediately. Call a Toyota dealer or qualified repair shop for assistance.
The light may occasionally flicker when the engine is idling or it may come on briefly after a hard stop. There is no cause for concern if it then goes out when the engine is accelerated slightly.
The light may come on when the oil level is extremely low. It is not designed to indicate low oil level, and the oil level must be checked using the level dipstick."
Old 12-02-2007, 07:02 PM
PAULUNM's Avatar
Wow, that is interesting! I will have to find that passage in my owners manual.
I have been advised to change the oil with a good filter and some heavier weight oil. If I keep getting the flickering light after that, I'll have the pressure read.
Old 12-02-2007, 07:28 PM
ciscojay's Avatar
FWIW, I have the same problem, exactly as the owner's manual states. It rarely happens, but mainly if I'm hitting the brakes hard to a stop, in gear, and pointing downhill. The second I blip the throttle, even just slightly, it goes away. I'm still going to get the oil pump and gauge/sending unit checked (not the $tealership though!) I'm up at that range (170k+ miles) where I'm more paranoid about stuff failing...especially something like this.
Old 10-25-2019, 08:32 PM
  #25
Julian82600's Avatar
Originally Posted by fillsrunner4
its gonna be either a ground but i bet if it were ground it would be more than just that light... so im gonna say buld. cheap and the easiest thing to replace
Is the ground expensive? My 04 4R V6 Sport is doing the same thing. The oil pressure light isn't flickering anymore, it remains solid. The engine light , stability, and trac are lit up on the dash as well now. The engine is ticking and I can tell its running different! I parked it as soon as all the lights came on the dash, and I haven't started it back up. It's at 204,000 miles and I know that's a lot.
Old 10-26-2019, 07:45 AM
  #26
aowRS's Avatar
That usually depends on the zip code.
Andreas
The following users liked this post:
millball (10-26-2019)
Old 10-30-2019, 04:40 AM
  #27
Old83@pincher's Avatar
Andreas
That's why I moved 2500 miles!
Gee...I would of tried a new low oil pressure switch...I cant believe I responded to a 12 year old post!
Old 09-22-2020, 08:16 PM
  #28
Marx Rojas's Avatar
Oil change
Had the same issue. Went away when I changed oil and filter. Sometimes the easiest thing is the solution.
southernZ
12-01-2011 06:20 AM
carson22r1984
11-03-2010 07:18 AM
skinnyhb
04-28-2008 11:15 AM
kawicowboy
11-28-2005 04:58 PM
Idea726
10-07-2004 02:14 PM
Quick Reply: Oil Light Flicker
