OBD codes - Evaporative Emission problems?
Originally Posted by WATRD
If you look at where the evap line enters the system, if the fuel is backing up into the filler neck, the inlet for the evap system is already "under water".
Too cold to run out and crawl under the truck.
Originally Posted by MTL_4runner
Hey Rob, You have any pics of where the line is?
#25
Originally Posted by <96 Runner>
Does the CEL on the 5VZ cause it to go into "limp home mode" or does it just light up with the same performance?
#27
I've seen people do the same thing, I make sure I screw it all the way. But thanks for the simple answer - amazing how many times the simple one is overlooked
#28
I have a 1999 4Runner V6 2wd and I just received the code P0446. I used to get a really bad fuel odor in the summer if I topped off, so I would just fill half a tank and it would keep the vapor pressure down, and my canister would not stink as bad; no CEL though. No that the weather is cooling down, I got a CEL, and when I checked it I got the code P0446. I checked my Hayes book but it is not very specific when it came to EVAP. Not sure if its the charcoal canister, the little vacuum sensor that travels over to another sensor through a tiny hose, or the sensor valve that travels to the top of my engine through a normal sized hose. I am told it could be the gas cap, one of those three sensors outside of my canister (all three have an electrical connection), or the canister itself. The canister seems to have valves inside of it too. Its a box shape with two cylinders on it with 6 hoses going in and out to many things. Everything is right there under my hood and accessible right behind the battery. What should I do... I refuse to take it to the stealership. I can fixed any thing on my vehicle with my Hayes book, but this one thing.
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
