Not moving when letting off the brake?
Old 08-10-2012, 05:38 AM
Sublime69's Avatar
This might be a stupid question but I just bought an 02 4runner with 116K miles. When I first start driving the car and let off the brake from a stop the car doesn't creep forward. After it warms up then it will move forward when letting off the brake. Is this normal? Every automatic car i have owned has moved forward hot and cold.
The car drives perfect tho, trans shifts great and fluid looks good too.
Thanks
Old 08-10-2012, 07:18 AM
DRCOFFEE's Avatar
sounds like the brakes aren't releasing. It should be looked at.
Old 08-10-2012, 02:08 PM
Sublime69's Avatar
Brakes seem ok.. the pedal is low but they are releasing
Old 08-11-2012, 02:51 PM
kball's Avatar
Leaking rear axle seals are known to bind the rear brakes up when cold. Not sure how cold you're talking about but if the back of your rear tire/brake hub is wet then there you go...
Flying91
45
04-11-2024 04:39 PM
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
coryc85
09-09-2015 06:24 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Not moving when letting off the brake?
