My 3rd gen done... for now.
Old 05-21-2008, 04:47 AM
  #121
Vermejo's Avatar
Here's the Beef
Old 05-21-2008, 05:13 AM
  #122
mkgarrison5's Avatar
beautiful truck bro..
Old 06-14-2008, 02:28 PM
  #123
Vermejo's Avatar
Full Frontal
Added a 3/16 skid extension (radiator protection) laser cut by my stepdad. The current set-up provided little to prevent damage.
After some full bumper contact and winch pulls my bumper is now crooked. The passenger bracket is bent and cracked, driver is starting to go. The shackle hangers are strong while the fins behind leave something to be desired. The brackets will have to be removed, straightened and plated. While I’m at it the frame end caps may need some strength as they have started to pull away.
Old 06-14-2008, 06:39 PM
  #124
xcmountain80's Avatar
Nice! thinking about production of these radiator guards?
Aaron
Old 08-03-2008, 07:12 PM
  #125
JulsTirn's Avatar
are you liking the km2
Old 09-06-2008, 09:12 AM
  #126
Vermejo's Avatar
Armor Adjustments
The bumper hoops are .120 designated for minimizing or preventing panel damage at the front/rear. Thus far I have avoided damage in these high traffic areas from luck. The fenders and doors are fair game for the rocks.
Bud Belly Skid with reinforced center section below the transfer case. The section between the cross members is a long stretch and prone to bending with hard use. The skid sections over the cross members may still require additional low-profile ribbing with this new skid. The disadvantages to a very rigid skid may be the transfer of force to the cross members and frame. Straightening the skid may be near impossible. Expecting 3/16 under the force of a 5000lb vehicle not to bend is asking a bit much. Thanks to Budbuilt for getting me the new skid with short notice.
Old 10-01-2008, 08:20 PM
  #127
JulsTirn's Avatar
beautiful
Old 10-01-2008, 08:32 PM
  #128
wormhole's Avatar
Yep, bending them back is a pain. Did you sell you old skid back to bud or just it and then got a new one??
I still have to try and bend the belly skid I have back (no dice so far)
Old 10-02-2008, 01:44 PM
  #129
1stgen4gunner's Avatar
I know this sounds kinda far fetched, but do you guys think that those trd rims will fit on a 88 4runner?
Old 10-02-2008, 05:23 PM
  #130
Sure why not?
Aaron
Old 10-02-2008, 07:28 PM
  #131
Vermejo's Avatar
Heavy machinery will do wonders over a hammer or jack in terms of getting it back to normal. My new skid is a chance to reduce this occurrence; additional reinforcement is still in order.
The TRD wheels will bolt up to your truck.
Old 10-02-2008, 07:46 PM
  #132
cackalak han's Avatar
Nice rig! My old 4Runner had the same A* sticker on the rear window.
Unfortunately, that's about all our 4Runners share in common....
Old 10-04-2008, 06:56 PM
  #133
Vermejo's Avatar
Steering Shaft
Wheeling IFS makes the accuracy of clunk diagnosis difficult as some parts are on their way out as others have just been replaced. My former 01 Tacoma and current 98 Runner have both been plagued by sloppy steering. In this case after recently replacing a broken rack I began to search for the remaining play in the steering. After searching and exposing the steering internals I found play in the steering shaft (above the firewall). I found a TTORA thread that covered the problem in great detail.
http://ttora.com/forum/showthread.ph...+wheel+removal
I had planned to do a write-up but stopped taking pictures after my hands became greasy. If anyone has any questions about doing this I’m happy to answer.
The steering is beautiful now.
New shaft is tacked to prevent play
The plastic joint had excess play
-Two will make the job easier
-Understand the airbag
-A steering wheel puller is not required; just don’t break your nose
-Getting the snap ring back on the shaft is a PITA
-The anatomy of the steering column is amazing
Old 12-30-2012, 08:52 AM
  #134
outlawredcvyota's Avatar
Where did you get your diamond trim I like the way it looks very sleek.
Old 12-30-2012, 05:33 PM
  #135
hrt4me's Avatar
Wheeling IFS makes the accuracy of clunk diagnosis difficult as some parts are on their way out while others have just been replaced. My former 01 Tacoma and current 98 Runner have both been plagued by sloppy steering. In this case, after recently replacing a broken rack, I began to search for the remaining play in the steering. After searching and exposing the steering internals, I found play in the steering shaft (above the firewall). I found a TTORA thread which covered the problem in great detail.
thanks, I will have to tackle mine one day...
Old 01-22-2013, 06:24 PM
  #136
SierraMtns's Avatar
Any more updates on your runner? I know its been a couple years since you started this thread.
Old 11-28-2013, 12:58 PM
  #137
dishhhman's Avatar
I took the side trim off my runner too. Those aluminum decals were a smart idea. Thinking of doing the same thing until I can get the body work done. Where did you get them?
Old 01-21-2014, 11:58 AM
  #138
I know this is more than a year later, but just FYI, he's unfortunately moved over to the dark side...
http://www.newmexicobackroads.com/p/nmbr-rubicon.html
39 Thieves
01-06-2017 01:08 PM
digitalracer
05-16-2016 03:57 AM
jerusry
10-19-2015 05:28 PM
digitalracer
08-17-2015 06:01 PM
snap-on
08-10-2015 05:19 PM
Quick Reply: My 3rd gen done... for now.
