Lucas Stop Leak (Oil)
Old 04-15-2012, 04:24 PM
streetlancer's Avatar
Originally Posted by Texas_Ace
It is not your normal RTV, it is FIPG, RTV on steroids. It works fine actually, better then most gaskets I have used. The only issue with it is getting it off, it is not fun trying to clean the surface to reinstall it.
You beat me to it!
Old 04-16-2012, 03:24 PM
StarGazer's Avatar
Shop called today. Valve cover gaskets...feel like an idiot. The leak was dripping down the back side of the engine. Mechanic told me that he usually does not see oil pan leaks from 4Runners.
Old 04-16-2012, 03:26 PM
Texas_Ace's Avatar
Yep, same thing my engine had/has. Replaced the valve cover gaskets awhile back and it worked for awhile but it started a slow drip again awhile back. Not a big deal, never makes it to the ground, just smells bad on first start while it burns off the little that dripped.
I see no reason to mess with it.
Old 04-16-2012, 03:32 PM
BMcEL's Avatar
Valve cover leaks are pretty common. My veezy has had a very slow leak for a few months now. Just waiting so I can send the injectors in and adjust the valves while I'm in there.
Old 03-28-2017, 03:17 PM
  #25
Yotakid96's Avatar
Same
Originally Posted by Batsoff
I have a similiar issue StarGazer...
At first I thought it was the valve cover gaskets, so I replaced those without much luck in solving the issue.
Then I had the shop pull the front diff and re-seal the oil plan, that also did not fix the issue.
So I have still have an oil leak somewhere on the back of the engine that no one seems to be able to find. I'm open to suggestions on where to start looking.
-batsoff
2000 4Runner Highlander
i have the same issue as you batsoff in my 94 4Runner
i changed my transmission filter and gasket put an extra RTV coat to keep it extra sealed. New valve covers new hoses is some spots just about anything I've seen wrong I've fixed but still can't find out where this leak is... it's very small to maybe a drop or 2 of oil a day. Any suggestions
Old 03-28-2017, 04:01 PM
  #26
millball's Avatar
Drop or two a day???
Fogettaboutit. It's a near 25 year old truck. You won't use 10 dollars worth of oil in 5 years.
Old 03-30-2017, 09:27 AM
  #27
Yotakid96's Avatar
it drips only when it's running pretty much but yeah a few drops a day not much still though, I don't want a leaking truck in my drive way. It has to be a little fix just gonna take some time to find out where it's coming from
Old 03-30-2017, 09:37 AM
  #28
millball's Avatar
Perfectionists who buy brand new expensive cars and trucks are still often disappointed.
It's not a perfect world.
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
Ladythump
22
11-09-2015 08:53 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Lucas Stop Leak (Oil)
