Loud shrill on acceleration
Fix it? I dont know. I'm at 300k and it sits now that I drive 2 hours every day. So probably selling time.
But, I am so curious to what the oil filter look like.
Thanks
Thanks
Well went to the local dealership.
Had to get the tires balanced/rotated (which the dealer has the right adaptors, works great).
The tech said the noise was from the muffler. The damper is split/worn and makes a high pitched whistle/shrill. Guess what, I believe him.
Anyone else hear of this?
With 300k miles time for a muffler!
Will let you know when I change some time in the near furture. Anyone have a good 3.4 muffler they want to sell?
Mike
Mike
#26
Sounds a litltle horky. Not sure why, but lucas did seem to help a lot, but not for long.
MAybe I will bolt my daughters 4runner exhaust onto mine. Too much trouble?
#28
I bought the bosal exhaust ($110). Bolted up, after I cut the muffler off to remove. The tail pipe bolts were welded on. Had to use my angle grinder to remove!
Once installed the noise was immediately gone. Note: just pulling the 4runner into the garage I had the noise!.
How abouit that!
ML
How abouit that!
ML
