help with a 96 2.7L tacoma
Old 05-07-2013, 07:09 AM
gabby722's Avatar
hey guys thought i would try here and see if i can get any ideas on what to try next. I have a 96 2.7L tacoma that while driving died while going down the road. I pulled it back and seen i wasnt getting any spark. I replaced all the plugs, plug wires and the ignitor i got a used one from a pull apart. I also put a new distributor in it with a new cap and rotar. I then seen i was getting spark but still turning over but not starting, so i check the circuit open relay and its working and the pump is spitting out fuel when i try and crank it but no start. I then tried to spray gas in through the breather into the carb with no luck of starting either. Kinda of stuck here and not sure where to look next? Thanks in advance for the help
Old 05-07-2013, 07:54 AM
redbayredneck's Avatar
What motor do you have? I've never heard of a carbed 2.7L in 96.
Old 05-07-2013, 08:09 AM
gabby722's Avatar
sorry bout that didnt mean the carb. just the 2.7L 4 cyl
Old 05-07-2013, 08:17 AM
gabby722's Avatar
also it is not throwing any codes now. It did throw the P1300 code till i replaced the ignitor and that went away.
Old 05-07-2013, 09:22 AM
Does it act like its trying to start at all or just crank and crank and crank?
Old 05-07-2013, 09:38 AM
gabby722's Avatar
it just keeps cranking, almost like it is not getting any fuel. It never sputters like it tried to start at all.
Old 05-08-2013, 07:02 AM
Fordless's Avatar
Did you put the distributor in exactly as the old one came out? ie did you mark the rotor and the case? If you didn't your way outta time and you'll have to set @TDC on #1 and put the dist on #1 cylinder. That'll be close enough to get it started.
Old 05-08-2013, 07:07 AM
gabby722's Avatar
I will have to try that and see if it helps. I thought i did when i replaced the distributor but i did have to do someadjusting to get it in.
Old 05-08-2013, 07:22 AM
VANCE164's Avatar
Subd just rebuilt my 3rz and I'm getting no spark now but it started before pulled.
Old 05-08-2013, 10:43 AM
Fordless's Avatar
Just remember there are two TDC or the crankshaft hits 0 deg twice in a cycle. Best thing to do is pull the #1 spark plug and cut a coat hanger to just the straight part. Stick the coat hanger down in the plug hole. When your coat hanger goes to the top as you come to the 0deg timing mark then your on the correct one. Then center the rotor on the #1 wire terminal. Like I said that should get it started and allow you to time it from there. you'll need a timing light and you may have to jump the diag connectors, I know you did on the 22re.
Oh and don't forget to pull out the coat hanger and reinstall the plug w/wire b4 starting it.--just in case statement
Old 05-09-2013, 05:13 AM
gabby722's Avatar
will do, im going to give it a shot this weekend, thanks
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
irv
09-29-2015 01:04 PM
charlie_fong
09-27-2015 10:06 PM
Project90
09-24-2015 11:40 PM
Quick Reply: help with a 96 2.7L tacoma
