FIELD MONITOR UNIT - update w/ pics
Old 09-13-2010, 06:39 PM
fightman80's Avatar
Smile
Sweet write-up man! I didn't know you were on YotaTech too!
Old 09-13-2010, 06:45 PM
blcktpgsr's Avatar
Originally Posted by Nelsonmd
Hey Blcktpgsr, great write-up. This has inspired me to try it on my 4runner as I have the same oak interior.
How has the spraypaint held up? I will have to do the same thing when mine comes in. Is the texture pattern of the original vinyl maintained by the paint?
Also, what color is that? I can't seem to find a retailer for that plastic spray paint, so I may have to order it.
Sorry for the late reply..the paint color I used is Satin and it's really holding up well and yes the texture pattern is still maintained even after several coats.. Try and find a craft shop/store..surely they carry some kind of plastic spray paint if not from your local hardware store..Good luck on your FMU build..you're surely gonna love it..to this day I still fiddle with mine..
Old 09-13-2010, 06:50 PM
blcktpgsr's Avatar
Originally Posted by ethernectar
Outstanding, any idea if something similar is available for 4th gen?
I've never heard of anyone installed a similar item made for the 4th Gen. Just not sure maybe Hilux Surf/4Runner Japan or Europe made one.
Old 09-13-2010, 06:52 PM
blcktpgsr's Avatar
Yup i'm also a loyal member here, I just keep going back and forth site to site.
Old 09-13-2010, 09:43 PM
  #25
scuba's Avatar
So what happens if someone doesn't have ABS?
Do you think the electrical VSS would have give the pulses off for the field monitor to operate properly?
Also, where are you getting these FMU's?
Old 09-13-2010, 10:42 PM
  #26
blcktpgsr's Avatar
Another point of contact i know of is the Diff ECU if ABS in non-existent. I have no reason to believe that the VSS wire coming off the ECU wouldn't work as well..RR Diff Lock perhaps? I'm sure guys who have installed the unit on their rigs would chime in anytime soon...
Got the FMU from this site: These are rare items and availability is unknown..you would have to send him an inquiry.
JDM Toyota - JDMNZ
Old 09-13-2010, 10:54 PM
  #27
scuba's Avatar
Never heard of a differential ECU..
I have a lockright in my Tacoma so no Elocker either.
Thanks for the link though.
Old 09-14-2010, 04:58 AM
  #28
Rock Slide's Avatar
And if none are avail. on his site, you can sometimes luck up on find them for sale on ebay.
Old 09-14-2010, 07:30 AM
  #29
Nelsonmd's Avatar
Yeah, I saw the satin in the pic. From what I see online, that is the texture, not the color. From Krylon's website, I am guessing it is Satin Khaki? Depending on what computer I am on, the colors look different, so I am not sure if that is the only one even close (not on my normal computer right now).
BTW, I just ordered one of these from Henry at JDMNZ. Now if I can just get my 4runner running and inspected, I can install this thing and enjoy it.
Old 09-16-2010, 07:14 AM
  #30
Nelsonmd's Avatar
Any word on the color? I have found the fusion line in several stores, but no colors close to the tan interior panels of my 4runner
Old 09-16-2010, 07:48 AM
  #31
blcktpgsr's Avatar
I'm looking at the spray can i used and it says "42438 Satin Khaki". That's the closest color i found that nearly matches the headliner, visors of my truck.
Old 09-16-2010, 07:51 AM
  #32
Nelsonmd's Avatar
Perfect, Thanks. Colors can get warped on the computer screen, so I really didn't want to try to match color off my monitor if I have to order it.
Old 09-27-2010, 06:23 AM
  #33
Nelsonmd's Avatar
Received my FMU on Friday, painted it that night, and installed it saturday. It looks great, works great, a definite winner in my book.
My wiring install was a bit different than this one though. I have different sunroof controls (I have one rocker switch that does both the tilt and the slide) which means I had to wire it a bit differently. I'll post the walkthrough when I get some pics and get it written up.
The rest of the wiring and install was almost identical to this one though. Thanks again for the writeup!
Old 09-27-2010, 06:50 AM
  #34
Rock Slide's Avatar
Here's how I did mine: https://www.yotatech.com/forums/f2/h...up-pics-94277/
Old 09-27-2010, 07:50 AM
  #35
Nelsonmd's Avatar
Originally Posted by Rock Slide
Ah, I see what happened, yeah, we had the same thing and I didn't realize it. I ended up cutting the blue connector off my original unit before realizing I didn't need to do that. I ended up soldering it back on, so we ended up with the same thing.
I am very glad that they didn't redesign much in the overhead unit and the new logic board for the one button fit exactly in it's place.
I should have looked more closely at your install thread first, I could have saved myself some soldering. Oh well, it is up and in now, so I am not touching it until I have a problem.
EDIT:
BTW, I also had a loose rearview mirror that I was able to fix while doing this install. I removed the mirror assembly and there was a little mounting bracket that was sandwiched in by 2 little barrel spacers. The barrel spacers were a bit smooshed, so I used a small straight edge screwdriver to open them back up a little bit. Fixed all of the wobble in my mirror.
Old 10-14-2010, 06:34 AM
  #36
Nelsonmd's Avatar
So I discovered an interesting little factoid last night...
I decided to try for a closer color match than the too-light tan that blcktpgsr used. I found another brand of spray paint that had a vinyl line with a color extremely close to the original color
http://semproducts.com/Catalog.asp?prod=190
I think I used the saddle tan color
Anyway, I cleaned the housing (tried to take the old stuff off with mineral spirits, but it did nothing, so I just decided to paint over it) and sprayed the new paint on, and almost immediately, it started bubbling and crinkling. WTF?
Apparently the new paint reacted with the fully dried old krylon fusion, and once they had reacted, I could just wipe them both off. So I was stuck with 2 messed up paints all over the thing. My only choice was to use the new paint as a cleaner essentially to strip off all the old paint. I scrubbed at for probably 30-45 minutes, finally getting most all the old paint off. Cleaned the vinyl, sprayed a fresh coat of the SEM stuff on, it took, and this morning I reinstalled. It looks great, and it extremely close to the original brown color of the roof console.
Anyone know why it did that?
I'll post some pics tonight of the new color. I love it, it looks great.
Old 10-23-2010, 04:46 PM
  #37
blcktpgsr's Avatar
Yeah I saw the final result with the paint color you used. and I must say that your FMU now closely matches the interior/headliner better than mine. I'll stick with what I got though coz now i hardly see the diff'rence anymore...good install by the way.
Old 08-02-2011, 06:12 PM
  #38
humphreys1588's Avatar
Will FMU work on 2nd gens? Such a cool system.
Old 01-04-2013, 10:34 AM
  #39
hrt4me's Avatar
Received my FMU on Friday, painted it that night, and installed it Saturday. It looks great, works great, a definite winner in my book.
My wiring install was a bit different than this one though. I have different sunroof controls (I have one rocker switch that does both the tilt and the slide) which means I had to wire it a bit differently. I'll post the walk-through when I get some pics and get it written up.
did you ever post your own write-up with pics?
Old 10-05-2014, 08:55 AM
  #40
nrgwar's Avatar
Thanks for the write up!!!
This Field Monitor Unit write up is for the sole purpose of simplifying the installation and to help understand the ins and outs of the process for those contemplating on doing the same mod. Big thanks to those who did this in the past and have provided invaluable resources and information. Take note that this was done on a '97 4runner, but can also be applied for models thru to 2002. sunroof or non-sunroof models use the same number of wires from the FMU.
here's what i used:
18v impact driver w/ phillips head
flathead screwdriver
ratchet set w/ 10mm socket
angle grinder w/ cut-off wheel
utility knife- used to trim the headliner
2- 25 ft. of 22 awg stranded wire
22-18 awg self stripping tap connector- red color
16-14 awg self stripping tap connector- blue color
5 pcs. of 1/8 dia. x 4ft. long shrink tube- used to insulate the whole wire span
soldering gun/ mini torch
lead...and lots of time and patience
Here goes...
First i removed the grab handles on both sides using my trustee dewalt impact driver, make sure you have the right size phillips bit to eliminate stripping, remember it's held tight with a blue loctite tread locker..
picture shows the bottom screw close to the steering wheel. do both sides.
removal of the trim piece is a snap, start by pulling from the rear edge of the front doors towards the dash..they're held by couple of clips and a hook on the bottom part.
next is to remove both sun visors..it makes it alot easier to run the wires with more room to play with.
remove the sunroof control by undoing the screw inside of that little compartment, once the screw is removed, push the compartment forward toward the windshield, then pull it down, remember to pull the connector out, this requires pushing down the female connector's tab and then pulling it out at the same time..save the screw for FMU mounting.
to remove the maplights and the rear view mirror, use a flat head screwdriver and pry off the edges of the mirror mount cover. it will then snap off easily by pulling it down. inside are 4 screw holding the actual assembly, remove and retain these screws..only 2 will be re-used to mount the rear view mirror..
next is the removal of the door sill which is held by 4 long phillips screw. remove the sill to be able to remove the kick panel which houses the ABS module. somehow get your fingers under the kick panel then pull it towards you..it should pop off..on my 97 the ABS is on the passenger side kick panel,,,i read that it's on the opposite side on 99's and forward.
now that the ABS module is exposed, remove the two 10mm bolt to get access to the back of the ABS.
you will then locate the light grey w/ blue stripe colored wire to tap into..run your two wires from the headliner down the passenger side pillar trim. one goes to the ABS and one to the clock wire. Extra care should be taken when fishing the wires using hanger wire..l
Do the same procedure on the drivers side and fish the 2 wires for the temp. sensor.
use your red tap connector and tap into the grey/blue stripe wire..top first wire looking from the back of the module(indicated by the tweezer above). make sure of a good connection, zip tie it, put the two 10mm bolts back and you're done with the ABS.
now the clock wire is accessed by removing the front dash trim for the stereo and temperature controls..behind the temp. controls on my '97 are 2 screws holding everything down, plus a couple of hold clips. remove the temp. control cover plate, then the screws and pull the entire dash off, in order to gain full access to the clock wire, few connectors have to be unplugged temporarily like the hazard and the rear window defroster.
unplug the clock connector and locate the green wire, tap your other wire coming from the passenger side pillar trim into this using your 22awg tap connector..put everything back and were done for the illumination.
Two down..two to go..
the drivers side is much easier as were only running two more wires for the temp. sensor thru the firewall and towards the sensors final location.
...so again from the FMU's location, two wires go down along the pillar, under the dash and the firewall. use your shortened coat hanger, tape the wires on the other end and punch through the rubber grommet, poke the grommet repeatedly until you know two wires can get through. Pull from the engine bay and if ready, connect the sensor and mount to its location, i left it for last..
i pre-painted the cover and the rear view mirror using Fusion plastic spray i bought from 'Michaels'..closest one i could find.
the headliner will have to be trimmed to accommodate the FMU, more than an inch towards the sunroof is needed and a bit towards the windshield(shown with the red dash lines). i suggest pre-fitting the ENTIRE unit, and verify how much will have to be taken off, take time- no room for error here. trim off until the unit sits flat against the headliner and the screw holes line up for installation. tuck all wires so as not to hinder the operation of the sunroof mechanism (if equipped) on your final install.
as for the mirror mount, remove the white male maplight connector from it. then trim off around the screw as shown in the picture below. use an angle grinder or a rotary tool with a cut-off wheel, file the edges of the new mirror mount. re-install the rear view mirror onto the newly cut mount and back to the headliner.
the FMU uses the plug & socket type bulbs whereas the stock uses the fuse style. for the maplights, I elected to use the existing maplight as the 12v source of power, the white male connector on the mirror mount still connects to the existing 12v power wire in the headliner.
See how the rest of the wires from the FMU are connected on the picture below. remove the white connector off the FMU and tap the wires as follow:
blue -temp. sensor
yellow/black -temp. sensor, connecting these two wires to the sensor wires is arbitrary.
green/orange -abs
white/red -switch 12volt(ignition on)
blue/yellow -constant(hot) 12 volt
green -clock(illumination)
white/black -ground, i also used the ground point for the maplights
sorted, bundled and zip tied.
the location of the sensor is just behind to the left of the right bumper lens. i mounted the sensor housing in a way so direct air doesn't hit the sensor itself....Everything works just as they should, the green bars roll as you move forward and reverse, compass directions move in the right headings. i also tried goin' up and the altimeter functions properly..the temperature readings are pretty accurate as per the weather network, turn the headlights on and the FMU screen dims accordingly. sunroof controls are good as well. Light off button to turn the unit on and off.
as for our finished product....
Hope this sheds a light in the installation of these nice units.. now i gotta eat!!!!
Quick Reply: FIELD MONITOR UNIT - update w/ pics
