Factory flares removal, damn holes!
Old 04-29-2005, 11:21 PM
Jboy's Avatar
How does one (me) fill them holes in the body where the flares were attached?
Old 04-30-2005, 12:06 AM
User 051420's Avatar
Bondo and paint....
Old 04-30-2005, 03:16 AM
Bigkahuna808's Avatar
Hey Jboy want to sell me the flares? As gapguy said, your gonna have to bondo and paint. Depends on the size of the hole though. I've done some work with little plastic plugs and touch up paint.
Old 04-30-2005, 05:26 AM
shazaam's Avatar
find some plastic plugs and give it that nissan frontier look
Old 04-30-2005, 10:35 AM
4Crawler's Avatar
I filled some of the trim holes in my '85 with a marine epoxy glue, it is fairly thick and very sticky. I just applied a blob to each hole, pushing it into the hole. Then once it set up most of the way, used a razor blade to trim it flush with the body. Since my truck is white as is the glue, I never bothered to paint it (all the holes are down on the rocker panel and mostly out of site. Has held up well for about 8 years.
When I removed my Bushwacker flares, I welded up the old rivet holes, sanded, primed and painted the fenders.
Old 04-30-2005, 07:43 PM
Jboy's Avatar
Wow that came out good.
Old 04-30-2005, 07:44 PM
Jboy's Avatar
I`ll keep you in mind if I remove them and decide to sell.
Old 05-01-2005, 12:04 AM
Rojadat
Old 05-01-2005, 10:12 AM
getitdone's Avatar
Hey 4Crawler, what kind of paint did you use?
Does it blend with the other panels as good in real life as it apears to in the pics?
Old 05-01-2005, 10:48 AM
4Crawler's Avatar
Just the Plastikote Import Color stuff at the auto parts store, match the factory color code to the color name and look up the matching paint. I think it took 1 or 2 cans to spray the fender.
Old 05-01-2005, 01:38 PM
jethro's Avatar
Go to your local marine store and pick up some marine-tex. It's a putty so you can mold it and smooth it out. Once it harderns, it's solid enough to sand like wood. Then just touch it up with some paint.
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
TJWilly
07-31-2015 02:05 PM
whereAreMyPants
07-22-2015 03:32 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: Factory flares removal, damn holes!
