Factory E-Locker Upkeep
Old Nov 8, 2008 | 12:51 PM
BushPig's Avatar
What do you need to do to properly maintain a factory E-locker?
My (new to me) 4Runner has one --- I know the previous owner NEVER used it, as she didn't even know what it was.
Should I engage it every once in a while?
What else?
Thanks!
Old Nov 8, 2008 | 01:00 PM
scuba's Avatar
Sure why not...maybe just to keep everything lubed up...
Old Nov 8, 2008 | 03:25 PM
Elton's Avatar
yep all i do is lock it once and awhile seems to keep it working
Old Nov 8, 2008 | 05:50 PM
BushPig's Avatar
Sounds good - thanks!
Old Nov 14, 2008 | 12:30 AM
Ron Helmuth's Avatar
well it is housed in the rear diff so synthetics in the front and rear pumpkins is not a bad idea...
Old Nov 15, 2008 | 08:18 AM
BushPig's Avatar
Do you recommend any particular fluid?
Old Nov 15, 2008 | 08:34 AM
X-AWDriver's Avatar
I'm using Redline in my diffs.
Old Nov 15, 2008 | 08:37 AM
BushPig's Avatar
Which Redline is it? 75w-90?
Old Nov 15, 2008 | 01:55 PM
Jay204's Avatar
Just make sure to engage it once in awhile....my friends tacoma came from the US and the rear-locker was never used...and it seized up....800$ for a new one!
Old Nov 15, 2008 | 01:58 PM
BushPig's Avatar
Yeah - good call.
I tested the e-locker the other day - I know it was the first time in a long time that it was used, as the previous owner never used 4WD --- I had to get a little forward motion to get the e-locker to engage, but it seems to work great. Definitely a sigh of relief on my part.
Old Nov 15, 2008 | 02:27 PM
Tacoclimber's Avatar
Wheel a lot.
misterzee's Avatar
That is perfectly normal. Same action on the disengage. a little turn to the left or right will help it in quicker.
Old Nov 15, 2008 | 03:19 PM
dbcx's Avatar
https://www.amsoil.com/storefront/svg.aspx
I can help youget it at cost also if interested.
Old Nov 15, 2008 | 06:24 PM
Rock Slide's Avatar
x2 on amsoil.
I just changed over my diffs, t-case & trans all to amsoil. Great stuff.
Old Nov 16, 2008 | 06:03 AM
Gerdo's Avatar
The only way to keep your e-locker working properly is to go offroading and use the locker!
JK
Lock and unlock once in a while.
Old Nov 16, 2008 | 11:24 PM
Meterpig's Avatar
Do the grey wire mod so that you can engage without throwing it in 4H or 4L. You will be surprised who much you can get around with just the locker.
Old Nov 17, 2008 | 05:17 AM
Jay204's Avatar
My friend did that with his tacoma, works great!
kawazx636
Oct 6, 2021 03:03 PM
I8URSVT
Jun 21, 2016 01:31 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
kbpickens
Oct 2, 2015 03:37 PM
tysen86
Sep 25, 2015 11:15 PM
