Evap system Not Ready
Old 12-29-2012, 09:42 AM
jgaynor2's Avatar
Just had some work done to the Evap system on my 2001 4Runner. How long does it take for the code to go back to Ready? Need to get my truck inspected. Is there a way for a tech to reset it to Ready?
Old 12-29-2012, 10:38 AM
Dirt Driver's Avatar
Use a code scanner to clear the code. If it comes back, there is still a problem.
Old 12-29-2012, 10:48 AM
jgaynor2's Avatar
I had someone runner the scanner but it showed no codes but when I went through inspection, no codes showed up but it the Evap showed Not Ready. Is there a way that can be reset?
Old 12-29-2012, 10:49 AM
jgaynor2's Avatar
Thanks for the reply Dirt Driver!
Old 12-29-2012, 12:14 PM
Alright, then you may need to drive the truck more to encounter all the conditions that activate the evap system. I was reading that some states will allow you to pass inspection with up to one or two systems not ready. Check your local regs to find out if yours is one of them. I couldn't tell from your post if the "not ready" status caused a test failure or not.
polo451
13
11-20-2016 07:49 PM
Linked2002
3.4 Swaps
7
12-15-2015 01:31 PM
viesail
08-17-2015 08:39 PM
TURBOrunnerNM
07-22-2015 11:01 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Evap system Not Ready
