engine spins effortlessy
Old 10-14-2009, 02:15 PM
  #61
vr4boy's Avatar
yup sludge galor
i openned up the drivers side and it was much worse
you can actually make golf ball size sludge balls from what i've seen in there-i think this motor is done for.
i'm chucking the long block and keeping all engine controls/emissions equipement and swapping them over on the JDM motor i ordered.
i found a jdm one at a really good price from a guy in florida w/ a 30 day warranty and guaranteed to me sludge free.
not letting this 4runner die-i'm giving it a new lease on life
i'll take pics of the swap as i'll be doing all the work myself as i've been there done that during my mitsubishi days....
here's whats coming next week:
Old 10-14-2009, 02:20 PM
  #62
Staff
DeathCougar's Avatar
Curious why you would do a JDM motor rather than one from a local wrecking yard?
Old 10-14-2009, 02:22 PM
  #63
mastacox's Avatar
Jesus she must not have EVER changed her oil for it to be that bad... It looks like a paving machine in there
You can probably part out some stuff on that engine though, like the intake, alternator, etc. etc.
Old 10-14-2009, 02:26 PM
  #64
mastacox's Avatar
I'm now morbidly curious to see the bottom end of that thing opened up, I'll bet the oil pan has a 1" layer of tar on it
Old 10-14-2009, 02:31 PM
  #65
vr4boy's Avatar
i shopped around my local salvage yards and seen the motors they offerred-some show signs of sludge,majority had 180k plus miles and range from $1300-$1600 for these motors-lower miles get the 2k mark.
i've had luck w/ jdm motors when i use to race mitsubishis(track only) so,i went that route.
private sellers on craigslist want the same amount too as salvage yards in my area w/ the same mileage and no warranty
so jdm i went
Old 10-14-2009, 02:33 PM
  #66
raydouble's Avatar
Old 10-14-2009, 02:34 PM
  #67
vr4boy's Avatar
i'm curiuos too lol
funny everytime i change it's oil,5 qts puts me at full hmmmm...
Old 10-14-2009, 08:47 PM
  #68
98runner210's Avatar
Can you really buy a JDM engine anymore. Seems everyone jumped on that bandwagon and started selling used engines from a yard at a premium and claims "JDM"
Old 10-14-2009, 09:05 PM
  #69
TC4RNR's Avatar
Originally Posted by vr4boy
i'm curiuos too lol
I and many many others doing DIY oil changes on the 5VZ-FE engine, 6 full qt oil is normal.
Old 10-15-2009, 04:26 AM
  #70
vr4boy's Avatar
they're still floating around but i think,supply is running low though...
QUICK QUESTION
is there add'l hidden headbolts on the 5vz motor? i took all head bolts off-8 bolts per side(12mm;12pt) and exhaust manifolds studs and for the life of me,can't lift the heads off-so much sludge in there i'm probably missing something.
seems like its getting hung up at the rear...
thanks again...
Old 10-15-2009, 05:53 AM
  #71
mt_goat's Avatar
QUICK QUESTION
thanks again...
Did you see the FSM for the head removal proceedure?
Also can't you use the long block for a core exchange?
Old 10-15-2009, 06:45 AM
  #72
mastacox's Avatar
QUICK QUESTION
YES
Each head has a single extra bolt, its a long socket head cap screw that uses a 6mm hex I think. The passeneger side is at the back of the head near the firewall in a pretty deep counterbored hole. The drivers side is at the front of the head it the symmetrically same spot.
Edit: I attached two pictures that show the holes in the block they screw into, and the approximate location on the passenger side head.
Attached Thumbnails engine spins effortlessy-img_0148_small.jpg   engine spins effortlessy-img_0157_small.jpg
Old 10-15-2009, 07:03 AM
  #73
mastacox's Avatar
You can actually see the hole for the screw in this picture. Why it's there I dunno, maybe to help seal the head near the coolant passage right there (although it has a low torque spec), or perhaps to foil the attempts of DIY mechanics like us.
Old 10-15-2009, 09:05 AM
  #74
vr4boy's Avatar
i'll be downloading the fsm at work and print my own manual
good thing about the JDM purchase,you get to keep your old motor-if space is available,i'll keep the block and toss out the heads.
i do have another 4runner-a 96 that had the strawberry milkshake issue i bought couple weeks ago,prev owner sold it at another real bargain...maybe use the block for it as it has 340k miles and it might be anytime soon
i got that running thanks to this forum-no evidence of damage to the tranny/engine.
thanks mastacox-i owe you a 6 pack
paypal u a $20?
Old 10-15-2009, 10:00 AM
  #75
mastacox's Avatar
You know the heads are probably in at least rebuildable condition. You might see if a head rebuild shop wants to buy them off you for $50 a piece or something. I wouldn't be suprised if you could part just that engine out and get more that you paid for the whole vehicle!
paypal u a $20?
Nah that's alright, glad to help a fellow Yotatecher. How about you just post pics of the bottom end of that engine for me
Old 10-16-2009, 11:49 AM
  #76
aowRS's Avatar
Holy Hell! That's an amazing amount of negligence....
Good luck getting this sorted.
Andreas
Old 10-16-2009, 12:16 PM
  #77
Matt16's Avatar
Originally Posted by algranger
I would say bent valves but you say the timing marks line up so idk. Thats reallyweird
The 3vze is non-interference, i believe the 5vze is the same if that's what you;re getting at.
Old 10-16-2009, 03:08 PM
  #78
raydouble's Avatar
Yes, both are non interference.
Old 10-19-2009, 06:59 AM
  #79
hross14's Avatar
No, but I said pop the valve cover, i bet that cam isn't spinning.
One pop of the valve cover revealed the problem
Hey i was right there also--I.e.--"no compression mean start tearing it down"
If i were you "Engine Sludge Guy", i would clean up what i could with the valve covers off, get your buckets moving again (ATF and Acetone 50/50 mix), put said valve covers back on and run a quart of tranny fluid with every 1000 mile oil change. Never know--it might just keep going--
HOWEVER Guys--i have been in a few of these motors and never seen or even heard of this--people must be trying to get 100K out of a single oil change HHHAaaaaa
And just to show you something else about these motors--i did 10K oil changes with Mobile 1 and when i got the motor rebuilt for more power--the builder said everything was in spec (165k on the motor) --didnt even have to touch the crank besides balancing it.
Old 10-19-2009, 07:13 AM
  #80
Matt3203's Avatar
can you not just clean it out and put it back together? forgive my ignorance haha
Quick Reply: engine spins effortlessy
