Does size matter? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-20-2002, 02:59 PM   #1 (permalink)
loosehead's Avatar
Does size matter?
O.k., now that I have your attention, I wanted to get some feedback from everyone about an idea I had regarding oil filters for the 3.4 V-6.
The other night I went to the parts store to get oil and a filter for my upcoming oil change. To make a long story short, I cross-referenced abunch of different filters and found one that is actually longer that ours, but has the same thread size, diameter, gasket size and valve pressure. So my question is this, for the same price, wouldn't it be better to use the longer one, since the lenght is proprtional to the amount of filter surface area?
Here's a couple of pics of the two different filters, courtesy of the Napa website:
According to the specs on the Napa website, the upsized filter is 1.4 inches longer, which would add a considerable amount of filter area.
Here are a few part numbers for the stock filter:
Napa Fil1348
Bosch 3330
Mobil M1-102
For the up-size:
Napa fil1516
Bosch 3422
Mobil M1-210
Motorcraft Fl-400S
The upsized filter is actually a Ford V-6 filter, from some 3.0L and the 3.8L Mustang of the mid-90's.
So what does everyone think?
I actually tried it last night to see how hard it was to get on, and I personally thought it was easier for me to get on and off than the stock one. The added length made it much easier to stab in from the wheel well, since you actually have more to hold onto. Also, I could not see any clearance problems, and it was pretty easy to get a strap-wrench on the end of it, too.
I look forward to any feedback in discussing this with everyone.
Cheers!
__________________
Jayson
1998 4Runner SR5 4WD
V-6, auto, E-locker
loosehead is offline
Old 11-20-2002, 03:09 PM   #2 (permalink)
Away
Dr. Zhivago's Avatar
Send a message via ICQ to Dr. Zhivago Send a message via AIM to Dr. Zhivago
Jayson, you rock!
He's my friend, you know.
Dr. Z
Dr. Zhivago is offline
Old 11-20-2002, 03:13 PM   #3 (permalink)
CTB
CTB's Avatar
My personal recommendation - go with either stock Toyota filters or Amsoil filters.
__________________
1995 4Runner V6 4x4
CTB is offline
Old 11-20-2002, 10:23 PM   #4 (permalink)
Send a message via AIM to Patrick D
Have you looked into whether Amsoil sells a filter for the Mustang? They most likely do and if so I would get that because you are right, more filter means better filtration.
And I will say it so no one else does,
Yes size always matters:tomcat:
Patrick D is offline
Old 11-20-2002, 10:31 PM   #5 (permalink)
jx94148's Avatar
Send a message via Yahoo to jx94148
Just because its longer dosen't necessarilly mean that there is more filter material inside. There might be but there is no way to be sure without disecting one like this guy does. .
jx94148 is offline
Old 11-21-2002, 06:36 AM   #6 (permalink)
Outkast`'s Avatar
I just had my oil changed too...DANG. O well next time I'll supply the filter (hey I know I'm not the only guy that has his weekend preplanned by his GF)
Great Thread Loosehead!,
Outkast`
Outkast` is offline
Old 11-21-2002, 08:39 AM   #7 (permalink)
WATRD's Avatar
Good catch
That is exactly what many of us with Tacoma's do.
The Amsoil replacement for the stock filter is the SDF57. But, somewhere along the way, someone figured out that there was a longer filter that worked perfectly for our application.
So, many of us switched over to running the SDF34, which is exactly as you described, about 1.5" longer, but identical to stock in thread and diameter.
I am on my third one of the longer filters now and have nothing negative to report. At least on the Amsoil, when we cut one open, we found that the extra 1.5" was indeed functional, giving us that much more filter surface area.
One word of caution; on non-lifted Tacoma's and I would assume that the same is true of 4Runners, the longer filter is just long enough to be a Class-A pain in the butt to get out of the engine compartment. If you have a couple of inches of lift, it works great, but many at stock height stick with the stock length filter.
__________________
-Rob
Slightly Modified 2001 Tacoma - WATRD.COM
WATTORA is becoming NWToys!
Tread Lightly! certified Tread Trainer
Search 100+ Toyota tech sites, including this one: Toyota Tech Search
WATRD is offline
Old 11-21-2002, 09:46 AM   #8 (permalink)
loosehead's Avatar
Quote:
Matt-
I've read that article, too, some time ago. Good point about the length issue. How about for the sake of science, I'll cut open a couple of filters and report back with some pics? I'll probably use the napa gold filters as my test specimens, since they are resonably priced and are actually a good filter. As the article points out, napa filters are made by Wick's and are a good product. I may go a head and cut open a Motorcraft, too, becaust they are also top notch.
WATRD-
Glad you chimed in, too. Like I said before, I did try taking putting the longer one on and off my 4Runner, which is stock height. I thought it was alot easier to get on that the short one. Since the short ones are also a pain to get off, especially ehn the have oil in them, this one will probably be similar. I guess the question then is the added increase in filter area worth the couple of minutes of inconvience while removing/installing it?
Thanks to everyone for the interest in this topic. I really would like some more input. If you think I'm completely wrong, please don't be afraid to speak your mind. I'll post more info next week after I cut up a couple of filters.
__________________
Jayson
V-6, auto, E-locker
Old 02-21-2003, 12:12 PM   #9 (permalink)
Away
I just wanted to post in this thread because I changed my oil today. I had 10,500 miles on my Royal Purple and even though it still looked good, I wanted to try the larger filter at the same time.
I used a WIX 51516.
Thanks for the info Jayson.
Dr. Z
Old 02-21-2003, 12:32 PM   #10 (permalink)
loosehead's Avatar
How was it putting the new one on, compared to the shorter, "stock" filters? Just curious if you had any trouble in case there are differences in that area of the frame thru the years.
And you are certainly welcome, Galen.
__________________
Jayson
V-6, auto, E-locker
Old 02-21-2003, 12:37 PM   #11 (permalink)
Away
It was about the same as putting the stock one on I guess. They're both kind of a PITA I think. I suppose there's a tighter clearance issue with the longer filter, but nothing that really bothered me. It sure looks better on there than that tiny stock filter. It seems so much more substantial. I always thought it looked too small.
Peace.
Dr. Z
Old 02-21-2003, 12:45 PM   #12 (permalink)
loosehead's Avatar
Glad you weren't cussing me (too much) while you were installing it...LOL.
I guess I should really cut open a few of these some day and report back. I'm such a slacker
__________________
Jayson
V-6, auto, E-locker
Old 02-21-2003, 04:15 PM   #13 (permalink)
Away
Yeah really Jayson. You are the poster boy for Slackers.
hehe
Dr. Z
Old 02-24-2004, 11:36 AM   #14 (permalink)
Erich_870's Avatar
I have two questions about using a larger filter..
1. My girlfriends dad was telling me that a larger filter takes longer to fill when you start it, so that is hard on the engine. I know some if not all filters have anti-flowback valves. Are these supposed to stop that? If they don't it seems to me a larger filter would be worse than the smaller ones. Also, will the larger filters require you to use more oil when you refill your engine then the stock ones? 1/4 a quart or more?
2. Won't a larger filter mean more oil is going to run out when you replace it? I have been fiddling with finding a way to keep the oil in my filter from running down my block and pooling on top of my front diff when I unscrew it. Has anyone tried to drive up on some blocks on just the passenger side to tip the filter up more so more oil drains out?
I never thought of the bypass valve opening becuase the filter is plugged before I change my oil, so I want to make sure that isn't happening anymore, by maybe using a larger filter.
Erich
__________________
99' Black Highlander 4runner / Garage Profile
Black powder coated 8x16 Wheeler Off-Road allow wheels / Husky floor liners / Thule MOAB rack / Custom Sub Enclosure / Back-up lights
"I don't high-light my hair, I've still got a pair, yeah honey, I'm still a guy.
My eye brows aint plucked, there's a gun in my truck, Oh thank GOD, I'm still a guy!" Brad Paisley
Erich_870 is offline
Old 02-24-2004, 03:35 PM   #15 (permalink)
Away
The myth your girlfriend's dad is speaking about started with the old style filters and Ford engines. I can't imagine a modern oil filter without an anti-drainback valve. You've probably noticed, when you remove an oil filter, how much oil drains out of said filter when you remove it. This same oil prevents a pressure loss when you start the car since the filter is already filled with oil.
As for the extra oil you have to add to make up for the extra volume that the larger filter provides, that is a good thing since more oil can carry more contaminents with a lower concentration per volume. It's not like we're over filling the oil system. We've just increased it's capacity a little bit. And what about a bypass system? Those typically increase the oil system capacity by at least 1 quart and usually more. More oil system capacity is a god thing, within reason.
What I usually do when changing the filter, is remove the skid plates first thing. Then, put down some newspaper and my catch pan underneath the driver's side lower control arm. Then, I SLOWLY loosen the filter and let the pressure release from it and wait a bit for it to drain as much as possible. I wait 2-3 minutes at least. Then spin it the rest of the way off and try to keep it as upright as possible when removing it. Some inevitably leaks out, but that's the way it goes. By removing the skids first, cleanup time is reduced as well as the size of the mess.
Hope this helps.
G
Old 02-24-2004, 03:39 PM   #16 (permalink)
4x4Lamm's Avatar
Is it really necessary? I'm not a mechanic but it seemes to me that if there is so much contamination in your oil that an extra bit of filter is a good thing, you have bigger problems. My engine has 193000 and I cut my last oil filter apart, it was covered in oil not bits of metal or anything. Am I missing something?
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it.
-1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now.
-2004 Tacoma SR5 TRD, My new daily driver. I love this truck!
4x4Lamm is offline
Old 02-24-2004, 03:47 PM   #17 (permalink)
Away
By providing a larger filtration surface, more particles can be removed since there is a larger surface for them to cling to.
It doesn't matter if the engine is pristine or not, ALL oil gets dirty and ALL oil carries contaminents in it.
More filter area is a good thing.
G
Old 02-24-2004, 04:19 PM   #18 (permalink)
Erich_870's Avatar
Hope this helps.
G
Ok, that makes sence. I forgot that when my filter is still seated on the block the oil is still inside, I was thinking the oil that did come out was just oil that didn't drain back into the pan because of a lack of holes on the bottom, but that's stupid . I agree with you on having more oil is better. I was just making sure that we should go by the dip stick reading to keep up with the extra need of oil.
Thanks,
Erich
__________________
Old 02-24-2004, 04:28 PM   #19 (permalink)
cruizin01's Avatar
Send a message via AIM to cruizin01
When I change my oil I just grab my funnel and a peice of garden hose I cut up and slide it on the end of the funnel. I wedge the funnel with the hose underneath the filter and unscrew it letting the oil drain into the pan. Sure beats spending time to take the skid plates off. I dunno how that would work with a 3.4 though.
Sounds like Ill be going with a 1516 filter next time
__________________
-Derek-
1998 Std. Cab Tacoma_4x4_2.7L_5 speed_PPG Gloss Black_2" RB BL_OME 882's & springs_33x12.50 MTR's on 15x10 Eagles_Westin Safari Bar_PIAA 520 SMR/Fog_Clear Lenses_Rear Diff Breather Mod_Manual Hubs_Taurus electric fan _Kenwood cd/mp3 player_Boston Z Comps_Boston Pro 10.5_fosgate 800.4_jbl 600.1_1 farad cap_bugshield_Magnaflow muff w/Borla tip_Tint 35-sides;20-back Pic Page
cruizin01 is offline
Old 02-24-2004, 04:52 PM   #20 (permalink)
Away
That's an excelent idea Cruizin'! I'll have to give that a shot.
And, YW Erich.
Peace.
G
Old 02-24-2004, 08:45 PM   #21 (permalink)
toy283's Avatar
Send a message via ICQ to toy283
The size difference between the two filters isn't all that great. I would be worried about fill-time during startup though. As far as drain-back valves go, most are garbage (including Toyota's). All filters will drain back, it is just a matter of time. I've seen the some of the Toyota filters drain overnight whereas others may take a week. FWIW, I currently run a pair of NAPA 1773 filters. These are about two inches longer than the 1516 and larger in diameter. They were originally for Ford heavy trucks and hold more than three quarts of oil by themselves. They require a remote mount setup to use and must be mounted upright so they stay full while the truck is shut down. My personal opinion is that larger/more filters are only marginally better for filtration (I don't alter the oil change frequency with them) but add oil capacity which aids in cooling.
__________________
Dave
Currently own no Toyotas :(
toy283 is offline
Old 02-24-2004, 10:08 PM   #22 (permalink)
Send a message via AIM to sigep4runner359 Send a message via Yahoo to sigep4runner359
Will the same filter apply to the 3.slow? Also toyota made the bigger filters for the longest time, the landcruiser filter was about 1" longer, but alas no more landcruiser filters.....
__________________
'95 Land Cruiser FZJ-80, some kind of Grille Guard with Hella Rallye 1000's
Yakima Rack, OME springs & shocks, Diff Lock,VHF Radio, Kickin Stereo!! (about to get some 33's & kaymar rear tire carrier)
You want your ski???
Go get it....
Warren Miller
sigep4runner359 is offline
Old 02-24-2004, 10:19 PM   #23 (permalink)
You should try putting a V8 Toyota Tundra filter on it. Same threads and width, but about an inch or so longer. I have never tryed it but I'm sure it will fit.
Mike.
__________________
1997 Toyota 4Runner Limited, 5vz-fe, auto, E-Locker, 265/70/16 BFG Allterrains
1989 Toyota Xtracab Pickup 3vz-e, 5 speed, 50L aux fuel tank, 8000 pound Ramsey winch, Tube bumpers front and rear SOLD
Bush rig 1986 Toyota 4runner 22re 5speed 31's, cb, more to come.
http://www.geocities.com/vdubster1
vudbster is offline
Old 02-25-2004, 08:18 AM   #24 (permalink)
X-AWDriver's Avatar
With my Eclipse it used a smaller filter than the '90-'91 DSMs so I used the earlier,bigger (by alot) filter and with the Puralator PureOne it did have more filter material;my friend cut one up to see.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 02-25-2004, 12:01 PM   #25 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
whenever i change my oil i always prime the filter before putting it on, so i wont have any starvation problems whan i start it, i have a 2.7, i dont know what direction the filter mounts on the 3.4, so this may not apply to it. Just my 2 cents
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Tags
400s, 51516, bigger, filter, fl, m1111, mobil, motorcraft, oil, quart, stock, toyota, version, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Timing light....does it really matter? nieuwendyk-25 Off Topic Talk 4 06-01-2007 04:07 PM
If money didnt matter.... AH64ID Off Topic Talk 40 07-01-2006 12:19 AM
Does bigger tires matter? callmej75 Off Topic Talk 22 01-18-2006 10:25 AM
Well, this was only a matter of time BT17R Off Topic Talk 4 12-31-2005 12:04 PM
Does the color of your vehicle really matter to YOU? obex26 Off Topic Talk 29 10-03-2004 12:26 AM
Content Relevant URLs by vBSEO 3.1.0
2009 InternetBrands, Inc.
