Do i need to change fluids?
Old 10-21-2002, 06:39 PM
914runner's Avatar
I have a 1991 4runner V6 manual 4wd and it has a little over 200,000. Im wondering if i should change the diff and transfer case fluid, it hasnt been done for at lease 100,000 if at all. So if i do i was thinking about running amsoil, but i dont know what weights to run, how many quarts i will need and what tools and parts i will need to takle this task at home.
Thanks
Old 10-21-2002, 06:59 PM
CTB
CTB's Avatar
Yes, definitely change those fluids if it has been that long since they were last changed.
I believe you should use 75-w90 gear oil in the front diff, rear diff, and transfer case. However, check in your owners manual and it will say for sure. The owners manual will also tell you fluid capacities.
All you are going to need is a wrench and some sockets.
Just remember - always open the fill plug first so that you are sure you will be able to refill once you open the drain plug!!!
Old 10-21-2002, 07:13 PM
914runner's Avatar
i dont have the owners manual. but does anyone know how many quarts i will need?
Thanks for the help!
Old 10-21-2002, 07:34 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Fresh from Corey's scanner
http://www.pnw4runners.net/tech/fluids/
Old 10-21-2002, 07:52 PM
Robinhood150's Avatar
Checkout this post.
Steve
Old 10-21-2002, 07:57 PM
914runner's Avatar
corey that helped a ton thanks.
Thanks to everyone else too.
Old 02-22-2015, 09:23 AM
Operation4Skinner1.5's Avatar
Yes! Please change your fluids!
Old 02-22-2015, 09:46 AM
Roark's Avatar
Whaaaaat
Old 03-08-2015, 11:25 AM
914runner's Avatar
Wow, my 12 plus year old thread lives again!
Old 03-11-2015, 09:58 AM
lekiboy's Avatar
Links are no longer working though.... Any chane of a link with part numbers for usual items to replace? Tnx
jasonty
41
12-23-2018 01:00 PM
Up&Down
08-11-2015 10:04 AM
Poppie51
08-02-2015 11:29 PM
rchavis
07-27-2015 07:41 AM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: Do i need to change fluids?
