denso 02 sensor part numbers?
Old 02-07-2012, 12:57 PM
mattbatson's Avatar
for my 1997 V6 runner...
I'm looking to replace both the one in front and the one in the rear of the cat.
getting the p0420 code again...
went to amazon, and the prices are great, but cannot tell which one is behind and in front of the cat?
Old 02-07-2012, 01:33 PM
mt_goat's Avatar
Look here: http://www.urdusa.com/More-Products-...89o0s114354g92
Old 02-07-2012, 01:54 PM
MudHippy's Avatar
89465 Oxygen Sensor
89465-39835 Front
89465-39855 Rear
Old 02-07-2012, 02:09 PM
TheDurk's Avatar
URD is good. I prefer to go to the source.
http://www.densoaftermarket.com/catalog/index.php
On the other board, there was one application that URD and Denso both had wrong. The wire was too short. (Sorry, it wasn't my truck and I don't remember which one.) Putting the Toyota number into the Denso cross-reference got it right. (Second tab on link above). Consider doing it both ways to be safe.
Old 02-07-2012, 02:30 PM
MudHippy's Avatar
Proof of the accuracy of my previous statement.
TOYOTA Oxygen Sensor part number 89465-39835 DENSO part number 234-4162
TOYOTA Oxygen Sensor part number 89465-39855 DENSO part number 234-4154
V6 4Runners:
1996-1998 Auto 4WD V6 3.4; Front = 234-4162
1996-1998 Auto 4WD V6 3.4; Rear = 234-4154
So yeah...let's see if we can make things any more confusing for the guy...
BTW, how the hell could Denso be right and wrong at the same time? Sorry, that makes no sense whatsoever.
Anyways, "part number" generally means the Toyota part number. You can ALWAYS count on it being correct. They built the thing, they know what parts go on it.
Source? I AM THE TOYOTA PART NUMBER SOURCE. RESPECT MY AUTHORITY!!!
Old 02-07-2012, 02:46 PM
mattbatson's Avatar
ah yes, that cleared it up for me
ok, went to amazon and ordered both of them up...thanks much for taking the time
Old 02-07-2012, 02:51 PM
BMcEL's Avatar
Hah.
Old 02-07-2012, 04:29 PM
TheDurk's Avatar
Relax. My statement is accurate. The application drill-down and the cross-reference of the Toyota part number provided different Denso part numbers from the same Denso site. Is that really hard to grasp? Yes, it makes no sense, because one of them was WRONG (the application drill-down.) Since URD presumably copied Denso's application listings, they had the wrong Denso number, too. I said they had it wrong for ONE application, not necessarily this one. Other people will read this besides the OP.
Toyota part numbers are great if you are buying from a dealer, but if you want the same part from an original equipment supplier at a much lower price, you need the manufacturer's part number--in this case, Denso. If a non-dealer seller, say on Amazon, posts a Toyota part number, then you are relying on a cross-reference done by that seller. I prefer to do it myself.
Sorry, but I've never been good about respecting authority.
Old 09-22-2014, 07:25 AM
outlawjar01's Avatar
Quick question: Is their a difference in part #'s between auto trans and manual trans???
Old 09-22-2014, 02:36 PM
TheDurk's Avatar
Usually....wire length tends to change.
Old 09-23-2014, 10:27 AM
vasinvictor's Avatar
Sensors should all the be the same. The different part numbers are for different wire lengths and plugs. My preference is to use Denso universals and cut and splice. They work just fine.
bigjstang
08-25-2021 12:41 AM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
cyclist231
07-07-2015 12:56 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: denso 02 sensor part numbers?
