Coil Over Mount/Bracket Cracked
Old 09-02-2012, 02:18 PM
EToy's Avatar
Anyone ever seen this happen? Both of mine have cracks in them. 261K on the frame. Not sure what to do since it's integrated into the frame. Maybe a re-weld, but seems like it's in a high-stress spot.
Open to suggestions!
Old 09-02-2012, 11:23 PM
NwRunner's Avatar
Damn, never seen that. Cant imagine its safe either.
Old 09-03-2012, 12:42 AM
wyoming9's Avatar
Red face
You might want to check with the dealer.
You should be able to buy them
I have to look closer are they welded to the frame?? I pretty much think they have to be.
If you can weld the welding is the easy part .
Taking it all apart and the prep work is what is going to be labor intensive if you have to pay some one.
If these are broke what other front suspension parts are in need of being replaced
Have you noticed abnormal front tire wear ??:wabbit2:
Old 09-03-2012, 04:01 AM
akaphilly's Avatar
thats crazy. have u been hitting any sweet jumps? to bad i just threw out my coil buckets a few weeks ago.
Old 09-03-2012, 04:46 AM
blake.nemitz's Avatar
you could always cut a ring of quarter inch steel and weld it on top, however i think the right way would be to cut off the whole tower and weld on a new one.
Old 09-03-2012, 06:02 AM
wyoming9's Avatar
Red face
I had thought that might work but I don`t think the threads on the studs are long enough.
To get full thread on the nuts just causing more problems perhaps.
Old 09-03-2012, 06:10 AM
EToy's Avatar
Ha, I know right! Looking at it you would think so, but nothing more than running some rocky trails around here. I have a really heavy custom bumper and winch up front so I don't know if that contributed or not.
The towers are welded directly to the frame. That's why I'm so torn over how to approach a fix. Plenty of donor vehicles out here in CO so I could try to find an old frame, cut them off there and then put them on mine, but man what a PITA! I like Blake's idea, but you're right Wyoming, it would be close for the studs.
Haven't noticed any weird handling or tire wear yet, but I really don't know how long it has been like this. I do know that driving up and down the mountain is going to be sketchy knowing its cracked!
Saw a rolling frame for sale on Craigslist in the area, so I even considered that option, albeit a huge project (although then I could build it from the ground up and upgrade everything!)
Old 09-03-2012, 06:18 AM
how about insatlling longer studs, what do they use one a spacer lift?
Old 09-03-2012, 06:29 AM
rworegon's Avatar
The shock coil bucket is available from the dealer to be welded in:
51501-35100 SUPPORT SUB-ASSY, SUSPENSION ARM RH
51502-35100 SUPPORT SUB-ASSY, SUSPENSION ARM LH
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...3557,3558,3560
Old 09-03-2012, 06:50 AM
EToy's Avatar
Wow, didn't think that would have even been an option. Thanks RWOregon! Now I just need to find a REALLY good welder in the area!
Old 09-03-2012, 06:55 AM
ive got arc, mig, and tig. gotta check with the boss but i could help ya burn them in
Old 09-03-2012, 07:11 AM
rworegon's Avatar
Welcome! The EPC has all sort of unexpected things in it.
Get ing.
Old 09-03-2012, 10:14 PM
wyoming9's Avatar
Red face
I did say I thought you would be able to get them at the dealer.
The welding is the easy part!!
It is all the prep work and getting things lined up and fitted where the real work is.
Old 09-04-2012, 04:54 AM
aowRS's Avatar
I'd say it's pretty safe to assume that the heavy bumper & winch, coupled with stiffer springs, caused the stress/fatigue cracks.
Before going through the hassle (and expense) of purchasing new towers, I'd pull the struts, straighten & clean the top of the towers, and properly weld the cracks.
That's a few hours of work, all in, and won't require an alignment afterwards.
Andreas
Old 09-04-2012, 05:02 AM
waskillywabbit's Avatar
Driving it like that period is stupid. You are asking for catastrophic failure.
Take it off the road and fix it as you cause an accident or worse kill someone knowing your vehicle is like this they'll own you.
:wabbit2:
Old 09-04-2012, 06:21 AM
DailyDrive's Avatar
I never seen steel crack. Unless it was tempered. And this should not be tempered.
Old 09-04-2012, 08:47 AM
KZN185W's Avatar
welding a plate on damaged steel would be a very temporary solution because cracks will appear later on the weakened steel and on the weldments.
the correct thing to do is to cut off the old tower and weld on a new one and if you can do both sides, the better.
Old 09-07-2012, 05:45 AM
aowRS's Avatar
Any updates?
Andreas
kawazx636
10-06-2021 03:03 PM
alexcarey
10-14-2015 06:05 PM
the_supernerd
10-01-2015 09:20 PM
puddlepirate
09-29-2015 08:02 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Coil Over Mount/Bracket Cracked
