Clutch pedal gets stuck!!!
Old 03-19-2016, 04:04 PM
MP's4R's Avatar
Originally Posted by billabob1234
Hey Mp's4r
My 96 4Runner is doing the same thing you describe. Do you recall what ended up fixing the issue? I keep seeing stuff on the internet about replacing the spring, but I'm thinking that if the clutch allows the gear to engage while the pedal is depressed, something must be hydraulically wrong.
Bill
Something is hydraulically wrong. Get yourself a slave cylinder and master cylinder, bench bleed the master cylinder and install per instructions and you should be good to go. Fixed my problem a couple years back and still works fine.
Old 03-19-2016, 04:19 PM
billabob1234's Avatar
Thanks for the response! I will do some research on how to do that.. May end up taking it to my trusty mechanic. Thanks again.
Old 03-19-2016, 07:08 PM
MP's4R's Avatar
Its really not as hard as it seems. I think the master cylinder was like 14 bucks and the slave cylinder was like 8 bucks. If you can bleed brakes then you can do this repair, and save yourself a few hundred bucks. Youll know if youve done something wrong cause you'll be worse off than you are now... Then take it to your mechanic...lol
Old 01-10-2018, 05:22 PM
MP's4R,
Just following up on this old post. I did end up replacing the master cylinder, and the clutch has been working well ever since. I appreciate the encouragement and advice
I'm getting ready to post my 4runner in the for sale forums, and was just looking over old posts. Thanks again.
Bill
akamon808
3.4 Swaps
12-16-2015 08:45 PM
duncanmc
08-19-2015 03:13 PM
Motomonty
08-09-2015 05:53 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: Clutch pedal gets stuck!!!
