Check Engine Light
Originally Posted by slemay6
2001 4runner 86000 miles Codes PO 440,441,446.They said it is the fuel system any guesses
https://www.yotatech.com/forums/f128/obdii-trouble-codes-76363/
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
And I agree with Humanoid.. check the gas cap. Past that, the evap canister could be plugged.
Did you reset the codes after tightening the gas cap? The codes won't go away by themselves, so if you didn't do it, disconnect your battery for 5 or 10 minutes (or pull the ECU fuse) to reset your computer, then reconnect the battery (or re-install the ECU fuse), start the truck, and see if the CEL comes back.
06-01-2021 01:51 PM
