Old 03-30-2016, 03:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
Beware: Power Steering air control valve
Old 03-11-2013, 10:01 AM
Notraps's Avatar
Originally Posted by brianh699
The part shown earlier in this thread is $70 plus $10 to ship here https://parts.tituswilltoyota.com/pa...r_search.html?
Thank you Sir.
Old 03-12-2013, 12:22 PM
Notraps's Avatar
Just out of curiosity...is there a reason that they have a disconnected number? Seems a little fishy to me.
Edit...NM I'm slow today
Old 03-12-2013, 12:42 PM
Staff
DeathCougar's Avatar
I assure you the largest Toyota dealer in Tacoma/Fife that just went through a multi-million dollar remodel does not have a disconnected number
Old 03-12-2013, 04:22 PM
brianh699's Avatar
Don't know I never call them. I've ordered thousands of dollars in parts from them their legit.
Didn't see your edit until after I posted whoops!
Old 03-13-2013, 04:51 AM
  #25
Notraps's Avatar
Thanks guys. I am on a work network that doesn't allow 800#s hence the disconnected notice. I called on my cell and the guy who answered was more than helpful. Great prices too.
Def Legit.
Old 07-29-2013, 11:08 AM
  #26
big bear's Avatar
404 error, not found.
Old 09-27-2013, 08:27 PM
  #27
Gevo's Avatar
Broke this during removal.. that $70 price tag is stupid
added to junkyard item list...:/
Old 02-04-2014, 01:41 PM
  #28
creeve4's Avatar
Originally Posted by Buck87
I have been wondering... does it matter if the the two vacuum hoses get switched? I cannot figure out which hose goes onto the right side of the sensor and which one goes onto the left side. I cannot tell the difference in the motor or in steering when I switch them but I would still like to install them correctly.
I continued searching and found the answer. It does not matter if the hoses are switched because they complete a loop from the plenum to the idle up valve when the valve on the pump opens during turning.
I am in the same boat as you, how did you determine which hose connects which side?
Old 02-06-2014, 01:25 AM
  #29
BlazeRunner's Avatar
These things are notorious for failing on the 1UZ, and the major consensus with the LS400 guys is to remove the idle up valve and replace it with a bolt, and plug the vacuum on the manifold. This effectively removes the system and stops all leaking, etc... you do lose the idle up effect at full crank and idle, but it's only like +-200 RPM and you most likely won't even notice it's gone.. I bought a remanufactured pump for one of my LS's and it was plugged when I received it. The pump never worked, so I went brand new Lexus OEM for $550 (!!!) and it was plugged also from factory. I believe some 1UZ-FE models came plugged from the factory, such as the SC400. In other words, you don't need it and even Toyota knows it. I would just plug it and be done for like $5 or less. Just go match the threads at a local hardware store.
Old 02-06-2014, 06:11 AM
  #30
scuba's Avatar
I did plug mine with a bolt after the replacement valve failed within 5k miles.
Old 03-05-2018, 06:42 AM
  #31
toy_tek's Avatar
Anyone know what the tread pitch is for a bolt/plug? I need to buy a pump (my engine didn’t come with one) and don’t have the valve either -otherwise i could match it up. Thx
Old 03-19-2018, 10:30 AM
  #32
Skookum1's Avatar
I can't believe I have not heard of this issue until now. This thread saved my bacon! My oil level has been increasing about half a quart every 3k miles and getting black and thinned out. And my power steering has been going down with no leaks other than a minor drip.
I bought a honda drain plug M14x1.5 and it threads in mostly, but wont go in all the way to seal on the crush washer. Teflon tape should be the ticket. Thanks all
Old 03-24-2018, 09:01 AM
  #33
toy_tek's Avatar
I did a quick search for a 2003 3rz PS pressure switch and this is the part # I found. I wonder if it would be possible to change from a vacuum switch (i have a 99) to the electric, and wire it into the a/c idle up circuit (so the truck thinks the a/c is on when the PS pressure increases - thereby boosting the idle). I may look into that when i get around to wiring my swap.
Old 06-26-2020, 08:03 PM
  #34
Wyatt Nichols's Avatar
Where do the tubes go?
I cant figure out where to tubes go. I bought a truck and this part is all mangled with. Where do there two tubes connect? Where does the loop go?
Old 09-17-2020, 09:57 PM
  #35
Yodamotorhomes's Avatar
This is my first post but super important. I installed a reman PS pump and installed the air control valve from the old pump to the new one. Installed it and the threads were leaking. The valve has a female flare but the pump does not have a male flare to match up. How the hell do you seal this valve against the pump so it doesn’t leak?
Old 09-17-2020, 09:58 PM
  #36
Pretty sure the tubes don’t matter which port they hook to on the valve. They are two vacuum lines that originate in the intake.
Charecter1
11-06-2023 10:08 AM
06-01-2021 01:51 PM
coryc85
09-09-2015 06:24 AM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Beware: Power Steering air control valve
