Best Place For Firewall Wiring Passthrough ?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-15-2008, 03:11 PM   #1 (permalink)
Hello all,
I am hard-wiring 2 heated seat pads (driver and passenger seats) to my battery on my 2000 4cyl 4runner. I decided to wire each seat separately complete with its own in-line fuse holder (up to 30a). I've got all the parts (wires, wire connectors, terminal connectors, in line fuses, etc). What I do not know is the best place to pass through the firewall?
Also, when it comes to mounting the negative ground wire, should i put it on the one thats already there from factory installation (right next to my battery). Or mount the ground wire on a different spot? i remember there being other ground spots right next to the factory one under the hood on the perimeter of the engine bay.
Any insight from you guys is greatly appreciated as always.
BEST PLACE FOR FIREWALL WIRING PASSTHROUGH??
thanks again,
sk
skolinsk is offline
Old 11-15-2008, 03:18 PM   #2 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
As for the ground, just find a bolt near by or drill a screw through some metal. You don't need to route that all the way to the batter. The times I went through the firewall I went through the hole by where the drivers feet are. Any hole will do, that is just what I found easiest.
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 11-15-2008, 03:18 PM   #3 (permalink)
i know there's one hole on the drivers side that comes in below the drivers side fuse box, but i was having trouble getting a single 10 gauge wire through there, much less all 4 (2 pos, 2 neg). so i guess i should rephrase my question, is there a better place to wire through the firewall? or a better way to thread these wires through that pass through.
thanks yall
skolinsk is offline
Old 11-15-2008, 03:24 PM   #4 (permalink)
where can i find a bolt nearby inside from the car?? i just kinda figured i would have to go back to the engine bay to get a good solid ground
skolinsk is offline
Old 11-15-2008, 03:27 PM   #5 (permalink)
I used the bolt that holds the seat belt to the floor (amp is in the back seat). You can find some metal under the dash somewhere and zip a screw in or find a bolt somewhere.
__________________
JASON
Jason is right.
Old 11-15-2008, 04:38 PM   #6 (permalink)
Nuthuts96's Avatar
Location: Burlington, VT previous: Everett, WA; Bellingham, WA
another option, which i'm now regretting i haven't done (and have tapped a few +12volts wires already) is install an aux. fuse block in the cab, so only 1 wire (8/10awg, or BIGGER!) would lead from the (+) of the battery to the cab.
a little pricey, but, again, wish i did this from the get-go to clean everything up! link to a writeup/idea generator.
__________________
Scott
1996 White 4Runner-4x4-SR5-5 speed-gold trim
140k-265/75/16 Yokohama Geolander AT/S
Cupholder Mod- Overhead Console Mod
Nuthuts96 is offline
Old 11-15-2008, 05:22 PM   #7 (permalink)
Spence1016's Avatar
Send a message via AIM to Spence1016
i had to drill through the firewall to get the 4 gauge wiring through for my amp
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[
Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells
Foglights on bottom of rear bumper
Optima Yellowtop, Kc daylighters on front bumper
Vortex muffler and Trueflow airfilter
Spence1016 is offline
Old 11-15-2008, 06:41 PM   #8 (permalink)
Rock Slide's Avatar
Quote:
Check out this thread:
http://www.yotatech.com/f96/drilling...rewall-107677/
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, Modified TJM T15, Stubb Sliders, FX/TSX HID Projector Retrofit, 1st Gen Rollbar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Nitto TG 265/75s, WeatherTech Mats, Pioneer HU, HID Hella 4000s, LED Tail Lights, JBL Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod & Rear Diff Breather Mod
Rock Slide is online now
Old 11-15-2008, 07:56 PM   #9 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
That last link is exact what i did only with 2 bigger holes. Works great for me, i also installed a fuse block above those holes, 1 switched, 1 constant and a place for another constant.
__________________
Just call me TA
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck
All the Mods that can be done to 3rd Gens Thread
My thoughts on Gun control summed up quite nice:
Quote:
Originally Posted by sdstud212001 View Post
Guns kill people like spoons make people fat
Quote:
Originally Posted by Dare44 View Post
Im a firm believer in the saying "If you outlaw guns, only the outlaws will have them"
“Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns”
Texas_Ace is offline
Old 11-15-2008, 10:55 PM   #10 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
on my 98 there was a great fire wall hole i got three 16 ga wires for my lights a 4ga power wire for one amp and a 8ga power wire for the other amp ill take a pic 2morrow if you like
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is online now
Old 11-16-2008, 09:48 AM   #11 (permalink)
yeah please elton. all this feedback is helpful guys, but i think im a visual learner.
skolinsk is offline
Old 11-16-2008, 02:28 PM   #12 (permalink)
Kerby J's Avatar
Send a message via AIM to Kerby J
first one question y do u want to hardwire them and r u going to b running a switch with them bc if u dont they will run all the time and thus drain your battery and if u want them to have have good power just hook them up to the ignition on that way they wont run accidentally without your being in the car?
__________________
2001 4x4 4Runner SR5
Kerby J is offline
Old 11-16-2008, 03:07 PM   #13 (permalink)
mt_goat's Avatar
It's pretty easy to run a few more wires through the rubber boot where the engine harness goes through the firewall.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is online now
Old 11-16-2008, 05:36 PM   #14 (permalink)
ok guys, did it all up today. worked out pretty well i think. threaded the wires up each kick panel and underneath each seat respectively. both seem to work with 20 amp fuses in place (although i am trying to find the lowest fuse that will power them but not break). looks good, and im pretty happy with it overall.
to address kerby's question, i am hardwiring them because they kept blowing out the power accessory fuse when i had them running on the factory cig lighter.
as for making sure power is cut off when the engine is off... that would be my only improvement. its true (im pretty sure) that they are still fed power if they are not actually turned 'off' on the heat seat switch...i would consider having them tied to the engine, but i would ask if this is there a similar setup to what i have now or is it a hole new project?? ideas?
skolinsk is offline
Old 11-16-2008, 06:20 PM   #15 (permalink)
Elton's Avatar
here's the pic
__________________
Elton is online now
Old 11-16-2008, 08:56 PM   #16 (permalink)
wow, where is that exactly??
skolinsk is offline
Old 11-16-2008, 09:07 PM   #17 (permalink)
Texas_Ace's Avatar
Looks to be beside the brake booster next tot he brake lines.
It would be behind the engine hard to see unless you are looking for it which must be why i have never seen it.
__________________
Just call me TA
Old 11-18-2008, 10:27 AM   #18 (permalink)
ok, so i think it will be worth my time (and battery consumption) to install a relay for these seats. I am considering just putting them in under the hood. I hope theres no problem here, as long as there out of the way. The only thing that might be of interest here is that I am in Vermont=COLD.
either way, the only thing im not sure about is if i need 2 relays, since i wired up each seat to its own in-line fuse. (im assuming a 30a relay will be the proper match for the 30a rated in line fuse on each setup.. even though its currently running on 15a fuse)..
Second, what do i want to be my "switch" input. keep in mind that if i do this under the hood, i'd like it to be something close, IE something under the hood near battery... either in the fusebox or somewhere under accessible the hood.
Again, thanks for your help in advance
sK
skolinsk is offline
Old 11-18-2008, 11:15 AM   #19 (permalink)
scuba's Avatar
Run both hot wires,to a switch you can buy at autozone and mount that on your dash , If you really want to get technical you can do a realy and all that.
__________________
No, I will not be your friend.
scuba is offline
Old 11-18-2008, 01:22 PM   #20 (permalink)
to be honest i think its less technical to just throw a relay in. that way i dont ever have to think about it... and i dont wanna fashion a switch or have to take apart the inside again really
skolinsk is offline
Old 11-18-2008, 03:26 PM   #21 (permalink)
A little tip,There is a wire that is 12 volt all the time(with or without key "on" if you have power seats and don't want to tap the battery.Its the seat power wire(soild blue,atleast for mine),located under both fron seats.Its a nice place to tap if you are running accesories,that are not going to pull tons of amps.Its protected by the "30 amp power" fuse.
If you want to run a wire to battery,go through the main boot..just follow the hood release cable,there is plenty of room for several wires to run through....use one of these if you want to be neat,if not some mechanics wire,coat hanger will work as well.
http://www.amazon.com/Thexton-436-Wi.../dp/B000P9IGCA
97ltd4x4 is offline
Old 11-18-2008, 05:02 PM   #22 (permalink)
Texas_Ace's Avatar
Ummm, he would still have to run a power wire from the battery using this method. Those wires for the seats are not big enough to handle 15+amps plus the saet. They will fry.
You could do it like i have my off-road lights done. I have a fues box under the hood mounted to the firewall (just because i could not find a place inside the cabin for it. I then have all my power wires going to behind the stock fuse box and have my relays tucked up there. This way they can't short out as easy.
Then from the relays run the wires to the seats and wire in some switches on the dash. There are some toyota offical drop in switches you can get for about $6 that will fit perfect into the pop-out slots on the lower dash by the drivers left knee. I have 3 of them and they work great. They can supposedly handle 20 amps by themselves but i went ahead and put both a fues and relay in.
But then you might also want to save those pop in switches for something else later.
__________________
Just call me TA
Old 11-18-2008, 09:02 PM   #23 (permalink)
i already tapped the battery. and i dont have the power seats unfortunately. shes a base 4 cyl, poor baby.. but i did wire each seat up already, just wanna attach a relay so theres no way it will run while im not in there. i think the hood is the best place to attach em, right after the in line fuse, i just dont know what to connect as the trigger for the relay... pics would be helpful..
skolinsk is offline
Old 11-18-2008, 09:07 PM   #24 (permalink)
Elton's Avatar
if your not sure how to wire up the relays this will give u idea
http://www.4runners.org/image/hella5...auxfusebox.jpg
__________________
Elton is online now
Old 11-18-2008, 09:08 PM   #25 (permalink)
Texas_Ace's Avatar
Ok, i see what you are saying, i did this exact same thing with my extra cooling fans.
In my case i tapped the power wire to the cig lighter (the one that only works with the key). I ran it to a relay and that relay then powers a fuse block that then powers a few things.
In you case just use it to power the relays, or you could do it like mine and have room for later.
__________________
Just call me TA
Tags
08, 4runner, amp, amplifier, auto, car, connects, drill, firewall, install, passthrough, place, terminal, toyota, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Firewall Grommet iscool007 86-95 Trucks & 4Runners 8 04-26-2007 06:38 PM
Cracked Firewall Jmunk Maintenance & Repair Archives 1 10-24-2005 11:48 AM
Best way to get through firewall? NMcruser 95.5-2004 Tacomas & 96-2002 4Runners 2 03-07-2004 07:54 PM
Disabling XP firewall? Toyota Punk Off Topic Talk 3 07-16-2003 12:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0
2009 InternetBrands, Inc.
