battery light help
Old 05-16-2008, 09:55 AM
davis131's Avatar
battery light help
My battery light on my 97 4runner reciently came on.I had the battery out for 2 days while I installed 2 new airbags and module, I put a new battery in and the alternator IS charging. I'm at a loss. It wasn't on before, just the airbag light but the bags and module took care of that.Could that be something that has to be reset? Thanks Bill
Old 04-14-2013, 04:11 AM
DRCOFFEE's Avatar
Dd you ever figure this out? What was the problem?
Old 04-17-2013, 10:48 AM
zipposrule's Avatar
check the fuse, bought my 95 with the same problem, changed alternators and put a new battery in it before i realized thats all it was. its in the fuse box under the hood and its a 7.5 amp fuse
Old 04-17-2013, 02:00 PM
wyoming9's Avatar
Red face
that thread was from 2008!!
Old 04-17-2013, 07:26 PM
DRCOFFEE's Avatar
Okay, so I found my problem. The white S signal wire from the harness that plugs into the alternator had a break in it and lost communication with the battery. I soldered in a new section of wire and the battery light went off.
On a side note, my mpg improved because the alternator is no longer constantly running at full capacity.
Yota.Jay
28
10-22-2015 01:08 PM
AkitaDog
09-01-2015 08:05 AM
mluz013
07-24-2015 12:31 PM
Sandman
07-14-2015 12:36 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: battery light help
