Advice on removing IAC valve without stripping screws
Old 08-10-2014, 07:48 AM
BigHoss_27's Avatar
On 3rz engine Any help would be great doesn't idle up every time ac is on drops to like 500
Old 08-10-2014, 02:47 PM
wyoming9's Avatar
Red face
I never saw that engine but on my 3.4 I just take off the throttle body put it in a vice and take them off. Using a good screw driver not a cheap one
That sounds more like the ECM is not seeing the AC is turned on rather then a bad IAC
Are you getting the P0505 code.
Old 08-10-2014, 08:11 PM
TheDurk's Avatar
Not a GOOD screwdriver but a JIS screwdriver. Regular Phillips will strip. Get a set of JIS drivers for anything Japanese, from Yamaha Waverunners to Canon cameras.
http://www.instructables.com/id/When...rial-Standard/
Old 08-11-2014, 12:09 AM
wyoming9's Avatar
Red face
Just where have you found these ??
Most people give a blank look at JIS bolts now a screw driver??
Old 08-11-2014, 05:21 AM
rworegon's Avatar
McMaster-Carr online is where I bought a set of JIS screwdrivers several years ago.
Old 08-11-2014, 02:13 PM
wyoming9's Avatar
Red face
Thanks was going to check when I placed my next order.
Old 08-11-2014, 03:56 PM
TheDurk's Avatar
http://www.amazon.com/s/?ie=UTF8&key...l_6whqb0gor1_b
Old 08-11-2014, 04:14 PM
BigHoss_27's Avatar
The motor idles up some times and then not. It idled horrible when I first got truck It may be old cracked vacuum lines where can I get some of those at?
Old 08-11-2014, 04:20 PM
rworegon's Avatar
Pull them off and match the internal diameter up at the local auto parts store. Most places have vacuum hose in bulk and will cut off whatever you need.
smthwsn357
05-01-2024 07:28 AM
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
Iceman4193
07-15-2015 04:48 PM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Advice on removing IAC valve without stripping screws
